Old 21-04-2008, 05:19 PM   #1 (permalink)
ωιтн gяєαт gяαρнι¢ѕ......
rahulbalmuri's Avatar
Default Disk Management in Vista: Help
one day suddenly i lost a partition from my compuetr in vista but as i hav Xp also i can find it in Xp...
When i go to disk management i found that partition but when i click on make partition as active foll msg appears:
http://www.thinkdigit.com/forum/atta...1&d=1208778449
When i click yes the foll msg appears:
please help me:::::::
rahulbalmuri is offline
Old 21-04-2008, 09:49 PM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Default Re: Disk Management in Vista: Help
Well let me tell you one thing first, making a partition active means selecting the partition for booting i.e. system will try to find boot files on that partition and will boot. So making a partition active that does not have Windows Vista installed is not a good idea as it will lead to a halt at the booting procedure.
In ur case, the problem is somewhat different. It may be caused by some program u installed recently that might make the drive hidden.
debsuvra is offline
Windows Vista File Management Samystic Software Q&A 1 26-02-2008 05:17 PM
Does win-Vista better in memory-management than Linux? praka123 Open Source 14 22-05-2007 01:04 AM
Disk Management partition not deleting vivekrm007 Software Q&A 3 19-01-2007 11:17 PM
- by chris
