Old 20-04-2008, 02:27 AM   #1 (permalink)
neelu09's Avatar
Default Yahoo messenger help!!!
Yahoo messenger 9 beta doesn't work properly. In fact it never works. Whenever i click any button it crashes. Even when i try to report a bug it crashes. Is anyone else also facing same problem.
neelu09 is offline
Old 20-04-2008, 06:17 AM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Default Re: Yahoo messenger help!!!
Actually BETA does not always work properly and that's why it is named BETA
BTW it is working fine in my pc on XP but it does hang on Vista. That's why I use YM for Vista there.
Please let us know which OS are u using ?
debsuvra is offline
Old 21-04-2008, 05:00 PM   #3 (permalink)
use 8 for now,i too had problems with that 9.0 BETA
Regards
imageek is offline
Old 22-04-2008, 01:01 AM   #4 (permalink)
neelu09's Avatar
i use xp pro sp2. But i have had some problems with older versions as well. whenever i clicked sign in in version 8 the crashed.
neelu09 is offline
Old 22-04-2008, 06:39 AM   #5 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Then you have some problem with Yahoo! products in your PC. Try Pidgin.
debsuvra is offline
Old 22-04-2008, 07:12 AM   #6 (permalink)
sg1
On a quest for knowledge!
sg1's Avatar
Isn't that more of a "workaround" rather than a solution??
Could you maybe try removing ALL traces of Yahoo Messenger from your PC(including registry) and then download/reinstall a stable version of Yahoo messenger(non BETA)?
If it aint broke, then don't try to fix it!!!! :)
sg1 is offline
Old 22-04-2008, 05:44 PM   #7 (permalink)
it crashes without ne errors ??
do you have a firewall installed ??
it seems some kind of firewall problem to me...see if when you disable the firewall and then try signing in..does it crash now...
Regards
imageek is offline
Old 01-05-2008, 12:01 AM   #8 (permalink)
neelu09's Avatar
Did it but now it gives me an error. it says DrWatson Postmortem Debugger encountered a problem.
neelu09 is offline
Yahoo Mail integrates Yahoo Messenger alsiladka Technology News 27 14-04-2007 03:22 PM
Yahoo messenger, MSN messenger not working. djk Mobiles and Tablets 5 16-11-2006 11:03 PM
Yahoo! messenger 7 opens Yahoo! folder on clicking on a link Vishal Gupta QnA (read only) 5 21-10-2005 03:40 PM
Yahoo Multi Gold For Yahoo Messenger 7 ,Is it available ??? arnold QnA (read only) 19 15-10-2005 04:11 PM
how can block Yahoo messenger and Msn Messenger ..?? pr@k@sh QnA (read only) 12 15-03-2005 11:08 AM
- by chris
