Old 19-04-2008, 09:39 PM   #1 (permalink)
Seed is the Life!!
shift's Avatar
Default help me to remove this
everytime when i start windows i got "The security information is invalid or has been modofied. This program will be terminated"
help me remove this
OS is Windows Xp ServicePack 2
NOD32 and Avast installed
thanks in advance
Stupidity Causes Cancer !!
shift is offline
Old 19-04-2008, 09:58 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: help me to remove this
This is a virus problem.
1) First use cCleaner to cleanup your system
2) Boot in safe mode, and do full system scan using one good updated antivurs, and two good updated antispywares.
3) If possible, boot in safe mode with networking, and do full system online scan.
4) After you have done full scan, and system cleanup.
start -->> run -->> type
sfc /scannow
Insert windows XP CD when promoted -> restart when promoted
I hope this should solve the problem.
ravi_9793 is offline
How to remove program's listing from Add/Remove Programs Udaya Maurya QnA (read only) 6 19-04-2008 06:43 PM
Can I remove it! JhonCena QnA (read only) 1 04-01-2007 04:47 PM
how to remove this?? NagpurDaMunda QnA (read only) 7 22-11-2006 09:36 AM
How to remove this... ?? ShekharPalash QnA (read only) 2 25-04-2005 12:22 AM
How can i remove........... nipun_the_gr8 QnA (read only) 2 02-12-2004 01:57 AM
- by chris
