| Forum |
#1 (permalink) |
#2 (permalink) |
Check the settings & select your appropriate location i.e if your using airtel then select "Airtel India".
ShutterTux - Photography, Linux & Life! : http://shuttertux.wordpress.com |
#4 (permalink) |
Check the settings "Access points" in your phone.Check whether they are properly configured.
which provider do you use?
#6 (permalink) |
if you activated MO then your settings can as follows:
APN: Airtelgprs.com username : balnk password : blank there is no need to fill proxy i think.can you tell us whats medium i mean to say bluetooth or data cable.
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc |
#8 (permalink) |
CBZ is better than Pulsar
here bro!
dont connect to the net using PC suit...rather install ur modem drivers of ur fone...n then go to "network connections' of ur pc nad make a new dial up connection...i prefer this method coz its very simple...rather than using a third party softy.. hope this helps!! |
#9 (permalink) | |
If so, i will post the method to connect later.
#11 (permalink) |
Hi Rameeze, Which Bluetooth Dongle you use ? Is it Bluesoleil ?
If you are using bluesoleil.. you won't able to connect it with help of Nokia PC suite.. Please tell us which Bluetooth Dongle you are using thanks! Last edited by King-Of-Hearts; 19-04-2008 at 03:16 PM. |
#13 (permalink) |
hell boy
use manual settings in one touch access and define ur gprs access point i think airtellgprs.cpm or whatever{see it from ur phone.use datacable if u have one
like sly stallone i am bringing the pain the only difference is that i got SINGH in my name..,!! |
#14 (permalink) | |
Coz MO does not use proxy & you have specified proxy.
#16 (permalink) |
Donno, but AFAIK MObile Office does not use proxy.
Wait for others to reply.
#17 (permalink) |
the best way is already mentioned here...just install modem drivers of ur phone...luk for driver properties in device manager, select diagnosis n querry modem 2 check if its a success.....then hunt for d serial number of settings for mobile office(if airtel)....ie 1,2,3,4 or watever...lets say x...
for eg if ur phn has foll settings- airtel mms airtel fun mobile office then ur x will be 3.... now create new connection.... conn name - "make ur wish" user id - pass - phn number - *99***x# n finish d setup...now try n connect....it will work...gud luk ps: ur phn settings wont hv ip address username n pass....only access pnt as "airtelgprs.com" Enjoy~!
No Pain...No Gain |
#18 (permalink) | |
should I uninstall nokia PC suite before installing driver. thanx |
#19 (permalink) |
hell boy
if u have installed nokia pcsuite then u automaticaly install the derives for up phone! connect the phone in nokia mode or in pc suit mode then compute will automaticaly detect the modem and install the derivers. now you may exit the pc suit application and proceed with the above steps. i think this should help..and if your computer doesn't install the modem automaticaly them go to device manager and see for un installed modem then update the derivers with ur inf files..,..
#20 (permalink) |
dattebayo
even i had the same prob with BPL gprs. It uses proxy servers so Nokia one touch access cant connect. So i entered the proxy settings in Opera browser and it worked. if u use IE, enter it in internet settings.
Yoda: No. Try not. Do... or do not. There is no try. |
#22 (permalink) |
friend you don't need to do anything i m writing complete procedure to do all things as follows:
1)first of all uninstall pc suite from your pc. 2)install bluetooth software cd then connect your bluethooth dongle pc and check is it working for general file sharing with your nokia 7610 if yes then go ahead. 3) now go to control panel>> phone and modem options >>modems then select your modem it will looks like bluetooth DUN modem>>> then click on properties>>>> then go to advanced>>>> in extra initialization commands fill it as im writing here AT+CGDCONT=,"IP","airtelgprs.com" <cr> then click ok you done now go to network connections and create new connection in that panel dialing no. will be *99***1# please note then try to connect with it i hope you will able to connect if any problem arise please write here us.
#24 (permalink) |
can you able to connect your bluetooth to your phone if yes then you can share files between your pc and phone.
check by sending any text or mp3 file from your pc to your mobile through bluetooth.thats it and write here then
#26 (permalink) |
is there any modem shown if yes then follow steps which i already written above ask here if not solved your problem
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| like nokia pc suit | ismart | Mobiles and Tablets | 6 | 16-01-2009 11:52 PM |
| Motorola L7 Pc Suit | we4net | Mobiles and Tablets | 1 | 12-07-2007 03:33 PM |
| which graphic card will suit my pc? | ankitmodi89 | Graphic cards | 2 | 26-01-2006 01:20 AM |
| Which AV will best suit my needs? | MenTaLLyMenTaL | QnA (read only) | 42 | 27-12-2005 12:08 AM |
| BT Support FOR Nokia PC Suit | gaju6696 | Mobiles and Tablets | 4 | 29-10-2005 10:25 PM |
