| Forum |
#1 (permalink) |
here's what happening... (Rapidshare.com) i start the download through flashget, downloads fine untill after 3-4 min. download stops, now when i try to open the site through any of the browser , it gets timed out. when i ping it , i get a positive response. After 25-30 mins again i can access the site but the above events occur again. Now i did a system restore , spyware , adware scans , virus scans , deleted temp files etc still nothing.I even requested an IP change with my ISP which i got changed but still the problem persists.I tried changing Duplex /speed modes still doesnt work. I am out of ideas on what to do. Please help me out. EDIT: seems to be happening only with flashget, i will try and reinstall it and check then. EDIT2 Regards, amer. Last edited by amer; 16-04-2008 at 09:46 PM. |
#3 (permalink) |
yes i do, and i just now tried downloading thru other managers and it works fine with others .... so its a flashget problem i will try a fresh install of flashget and try.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Connectivity problem | maddy_in65 | QnA (read only) | 6 | 03-04-2008 09:48 PM |
| Nokia 3120 connectivity problem.. | mdp | Buying Advice | 3 | 02-01-2008 07:40 AM |
| Nokia N70 PC Connectivity Problem | abhi_alpha_beta | Buying Advice | 3 | 01-04-2007 10:14 PM |
| Problem with PC Suite connectivity.. | kumars | Software Q&A | 3 | 10-11-2006 12:21 PM |
| pls help. connectivity problem | anandk | QnA (read only) | 3 | 06-06-2005 09:58 PM |
