| Forum |
#2 (permalink) |
Legen-wait for it-dary!
Then... the comp at your home doesnt really have a good antivirus... the virus may be creeping and crawling inside your hard disk and memory... sloooowly your computer slows down... and you make a thread again, here, asking the reason and the solution... we ask you to download NOD32 and run it... and to uninstall symantec as it is a $^%%$#^(& antivirus, and you go back and try it, and post back saying "it worked, thx guys!!! digit forum roxxx" and we nod back, saying that has always been the case
I gave you a big hint on what to do next. I luv being sarcastic Seriously.
If the Start Windows Restart when Windows starts check box is checked Windows Restart will start automatically every time Windows is started. - Actual excerpt from a windows program help file |
#5 (permalink) |
doing R&D of webtools
you should use AVG free or Kaspersky. it is very efficient to remove the virus and your data will be saved as it is.
but can somebody tell me how do i set the default option when i double click on the pen drive icon. = the first option when i right click on the pen drive's icon in my computer it is open(O) or something like that which i want to change to Open only.
regards Amit Shah www.toolnext.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| DMA Problem on DVD-RW Drive | ronweasley | Hardware Q&A | 2 | 01-10-2006 06:28 PM |
| USB drive problem. | akshar | Peripherals | 8 | 16-09-2005 06:01 PM |
| pen drive problem ! | esumitkumar | QnA (read only) | 5 | 15-08-2005 02:26 PM |
| fedora cd iso problem(installation from hard drive problem) | harmax | Open Source | 3 | 01-07-2005 11:34 AM |
