Old 14-04-2008, 06:49 PM   #1 (permalink)
Default v3000 drivers installation problem..
I hope I am at right place to get rid of very irritation problem I am facing.
I am having v3000 notebook. I have recently installed win xp on that have downloaded drivers from the hp site for various components like audio, nvidia geforce 6150, ethernet and wireless.. But when I install any of these setups, I get the message that the drivers u r installing is not compatible with any of the devices, setup will exit.. in cse of audio message like unable to initialize the audio device comes.. Earlier the dealer has done all the installations.. so I was not aware of such problem.. Can any body please help me in that..
I shall be thankful
Amit Bhatia
bhatia_amit is offline
Old 14-04-2008, 07:08 PM   #2 (permalink)
Default Re: v3000 drivers installation problem..
Hi,
Don't you have the Recovery Disk ? Also let us know originally it was XP or Vista when you bought it.
>setup will exit
Manually Add Hardware through control panel & check it out giving the path of .inf file.
Hope that helps.
Janki
janki2008 is offline
Compaq presario V3000 problem Kaushal Hiwarkar Software Q&A 6 17-03-2010 11:35 AM
Ubuntu -restricted drivers installation help x3060 Open Source 6 16-12-2007 06:13 AM
WIN XP is not installing in Compaq Pressario V3000 Kaushal Hiwarkar Software Q&A 2 20-05-2007 11:17 PM
- by bhaskar
- by Soumik
