| Forum |
#1 (permalink) |
system: microsoft windows XP proffesional version 2002 service pack 2, intel(r) pentium(r) 4 cpu 2.66GHz 248 MB of RAM using- AVAST antivirus professional updated regurarly |
#2 (permalink) |
Legen-wait for it-dary!
Please, please do not lock drives. If you really want to protect your files, put them in a folder in the drive, and protect the folder.
That was just an advice, I found myself in the same situation when I tried Universal Shield some years ago. Fortunately I could unprotect it in the safe mode(I was using the trial version which did not allow protection in safe mode, the full version does) So, try opening it in safe mode. If you can access it, uninstall the software from the safe mode itself.
If the Start Windows Restart when Windows starts check box is checked Windows Restart will start automatically every time Windows is started. - Actual excerpt from a windows program help file |
#3 (permalink) |
the software is not installed its in rar & opens inside the folder please suggest an idea plz
#4 (permalink) |
Extract the rar somewhere then. And then run it. A security program without an install program? oO
The prog's website www.hihisoft.com has only a youtube downloader. Looks like the prog is discontinued... version 4.1 seems to be the latest, try to get a download link from google. Install it, do what I said, see if it works. Before that, did you try to boot in safe mode and check if its accessible?
#6 (permalink) |
i formated my drive
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| problem to open drive(ex. c:) | patelviren | QnA (read only) | 3 | 13-11-2007 11:02 AM |
| Drive does not open....help plz | sanphoe | Software Q&A | 6 | 24-04-2007 03:11 AM |
| Cannot open any folder or drive | mukilan | Software Q&A | 5 | 08-12-2006 06:39 PM |
| cd drive refuses to open | sidcool | Hardware Q&A | 7 | 24-01-2006 07:21 PM |
| DVD drive doesnt open DVD's | devil666 | QnA (read only) | 16 | 24-09-2004 11:54 AM |
