Old 14-04-2008, 06:28 PM   #1 (permalink)
Indidiot
Plasma_Snake's Avatar
Question Firefox Theme Problem
I downloaded 4 themes for firefox using Internet Explorer. Now as they are .jar files, Nokia PC Suite is their default program and if I open them using Firefox
, it asks where to save them. Is there a way to install these themes or just have to do with traditional online installation.
Plasma_Snake is offline
Old 14-04-2008, 06:32 PM   1 links from elsewhere to this Post. Click to view. #2 (permalink)
Default Re: Firefox Theme Problem
http://www.tech-recipes.com/mozilla_..._tips1118.html
legolas is offline
Old 16-04-2008, 12:22 PM   #3 (permalink)
Amir.php's Avatar
Arrow Re: Firefox Theme Problem
->Many times it is simple to add extension by setting extension open with always firefox.But themes can not be easily added.to add theme follow this step:
goto:
1- tools > folder option on my computer and check "Show hidden files and folder".
2- Now goto:
active drive(on which your windows installed) >document and setting>select desired user name from users(User account on which you have installed firefox)>Application data>Mozilla>firefox>profiles>ea1ix2wr.default>ext ension.
Now copy firefox theme and paste here.
3- Open firefox and it will insatalled itself.
Amir.php is offline
Old 16-04-2008, 12:26 PM   #4 (permalink)
Think Zen.
ray|raven's Avatar
^Huh, why so hard, just open the themes window and drag-n-drop the jar file onto it, firefox will ask you if u want to install it, say yes and restart , Simple.
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/85347-firefox-theme-problem.html
Mozzila Firefox Question?? [Solved] - Security Answers Post #0 Refback 25-09-2010 08:14 PM
Noia theme installation in FireFox pradeepbp Software Q&A 3 20-05-2006 12:05 AM
Firefox theme pickster Tutorials 3 28-02-2006 07:50 PM
FireFox Skin or theme ! ! ! ax3 Software Q&A 1 31-08-2005 09:07 PM
