| Forum |
#1 (permalink) |
I installed 'peerguardian 2' and was watching clips from metacafe . Suddenly all my icons and taskbar disappear from the desktop.I could only get taskmanager window after pressing ctr+alt+del.I am not able to get any programmes even on restart. I have tryed to repair Xp but no result.The same problem when windows starts. I am also using Avast antivirus.. Please help. |
#2 (permalink) |
Legen-wait for it-dary!
I dont see any connection between Peerguardian, metacafe, and avast.
Can you right click on desktop? If yes, right click, arrange icons->show desktop icons. Check that option. If not, for XP pro, start->run. type "gpedit.msc" without quotes, press enter. under User Configuration->Administrative Templates->Desktop see the state of "Hide and disable all items in desktop" if its enabled, double click it and choose disable, click ok and relog into your account. for XP home, start->run. type "regedit" and press enter. browse to HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\ Explorer or HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Policies\ Explorer depending on your problem exists only on your user account or in all user accounts. You need to look for a DWORD value of name "NoDesktop" if it exists, double click it, set the value as 0, and restart computer. if it doesnt, right click on the right pane, new->dword value type the name as "NoDesktop" and double click it, change value to 0 and restart comp. that should do it. <phew>
If the Start Windows Restart when Windows starts check box is checked Windows Restart will start automatically every time Windows is started. - Actual excerpt from a windows program help file |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Quick Lauch Icons & Tray Icons become LARGE | blackpearl75 | Software Q&A | 5 | 24-02-2008 01:54 PM |
| How to Increase Size of only Desktop Icons not other icons? | Vishal Gupta | Software Q&A | 3 | 17-09-2005 07:44 PM |
| disappearing of CD data | kumarn_2004 | QnA (read only) | 5 | 04-04-2005 02:06 PM |
| Start menu disappearing act | P3PoweR | QnA (read only) | 5 | 16-12-2004 11:11 PM |
| disappearing red | stan | QnA (read only) | 11 | 06-10-2004 12:37 AM |
