| Forum |
#2 (permalink) |
Stuck
You can run bootable disks by changing the primary boot device to that particular device (In ur case CD/DVD drive). You can do so by going to the BIOS settings by pressing DEL key (most u'll have 2 keep on tapping it continuously when u just turn the computer on). There on searching, you can find the boot sequence. Here you can change it.....
Hope my solution works.. |
#5 (permalink) |
guys! i am not able to boot from the digit DVDs. i have tried every method but still i am not getting success. is there some other method plz tell as i need to learn linux for my degree.
#8 (permalink) | |
u want to work on linux or u want to work on "fedora" PS:I kno fedora is also a flavour of linux ...
Regards |
#9 (permalink) |
You can try downloading livecd image from http://fedoraproject.org/en/get-fedora .With them you get option of installing the distro as well
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Booting Problem !!! | bajaj151 | Software Q&A | 6 | 23-09-2007 11:03 PM |
| Problem booting XP | opokharel | Software Q&A | 1 | 09-02-2007 12:45 AM |
| booting problem | amey kerkar | Software Q&A | 5 | 30-07-2006 03:36 PM |
| booting problem | ranjan | Open Source | 3 | 07-05-2005 01:50 PM |
