Old 12-04-2008, 08:34 PM   #1 (permalink)
CpyderGraphix
cpyder's Avatar
Default Wierd Internet connection problem. RediffBol conects and nothing else!!
My comp has started a funny problem. I have a DataOne connection. It was working perfectly fine. And then one fine day, no web pages would open. Gtalk / yahoo msngr would not work.. No other communication to the internet.. except.. RediffBol!! I could connect using virtual machine running linux (ubuntu)! I searched around and came up with fixing winsock.. used this command -
 netsh winsock reset catalog
it did not help. After a few days, it started working on its own. Then after about one week same thing is repeated, save one change. Now it doesnt connect through the Virtual Machine also. Yes, RediffBol still works - though intermittently. Okay.. so any pointers??
See you at anditworkedforme.com
cpyder is offline
Old 18-04-2008, 09:28 PM   #2 (permalink)
CpyderGraphix
cpyder's Avatar
Default Re: Wierd Internet connection problem. RediffBol conects and nothing else!!
OK.. I could fix this one up. Checked up the modem with another freind and it worked. The DNS servers as told by the BSNL were perhaps down. with those settings changed, every thing fell into place.
I found another thread cursing BSNL about similar problem here:
Wierd Internet Problem
May I request any mod to merge this thread with that.
-Thanks
cpyder is offline
Wierd Internet Connection Problem s18000rpm Software Q&A 24 23-02-2008 11:33 AM
Wierd Internet Problem iMav Software Q&A 1 16-06-2007 06:15 AM
Wierd Internet Problem kirangp Software Q&A 3 22-03-2007 07:45 PM
internet connection problem Pepsi™ Software Q&A 3 05-05-2006 08:50 PM
Wierd Internet Connection Sharing problem! SmoothCriminal Software Q&A 5 09-02-2006 01:58 AM
