Old 11-04-2008, 08:26 PM   #1 (permalink)
User Name's Avatar
Default help:Can't able to install XP SP2..
I Can't able to install XP SP2.windows always gives diff. diff. errors each time i try to install.
my system reboots automaticlly.
Is there any prob with RAM?
User Name is offline
Old 11-04-2008, 09:27 PM   #2 (permalink)
User Name's Avatar
Default Re: help:Can't able to install XP SP2..
i have checked both ram sticks each time error is same.
i can't able to figure out what is the problem?
Old 11-04-2008, 09:29 PM   #3 (permalink)
Different errors meaning? BSODs?
Plz elaborate.
Xccentricity is offline
Old 11-04-2008, 09:33 PM   #4 (permalink)
Attitude matters
Ponmayilal's Avatar
The first question would be whether you have genuine Windows XP.
Ponmayilal is offline
Old 11-04-2008, 09:43 PM   #5 (permalink)
User Name's Avatar
Plz elaborate.
means some time says file is currept sometime says fail to install catalog files
some time says can not find xxx.dll in i386
Old 11-04-2008, 10:17 PM   #6 (permalink)
y2j826's Avatar
seems like Your CDROM has some kind of problem, try to install it using other cdrom or clean ur cdrom's lens . . .
http://worldofy2j.blogspot.com
y2j826 is offline
Old 11-04-2008, 10:29 PM   #7 (permalink)
clmlbx's Avatar
Corrupted Data In Cd Try Installing From Another Cd...........
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is offline
Old 11-04-2008, 10:48 PM   #8 (permalink)
User Name's Avatar
i copied sp2 from cd on hdd then try to install it but no use.
actually sp2 installation extract the i386 files in memory and then installs files one by one.
so i don't think there is any prob with CD ROM.
Old 12-04-2008, 12:55 AM   #9 (permalink)
TooR
alok4best's Avatar
Problem must be with ur CD rom...Might be when u copied ur cd to ur PC, some file didnt copy properly...and SP2 installation doesnt extract files in memory(RAM)...it extracts on a hard disk partition having enough free disk space..
Better Download the setup from Microsoft website
I wish !!
alok4best is offline
Old 12-04-2008, 08:13 AM   #10 (permalink)
If your system reboots automatically ...then check your processor fans
Overheating may be a problem that might coz restarts ...
Regards
imageek is offline
Old 12-04-2008, 08:39 AM   #11 (permalink)
On KillingSpree!!!
scavanger007's Avatar
possibilities........
1]bad CD .....
2]bad CD DRIVE......
3]overheating.........
scavanger007 is offline
Old 12-04-2008, 03:48 PM   #12 (permalink)
User Name's Avatar
yes i also think it's overheat.
This is what i got in everest home edition
Motherboard 44 °C (111 °F)
CPU 43 °C (109 °F)
Seagate 42 °C (108 °F)
Old 13-04-2008, 11:10 PM   #13 (permalink)
TooR
alok4best's Avatar
CPU 43 °C (109 °F)
The temp which u have quoted are perfectly fine and normal...u will actually have CPU arnd 70-80 if its overheating.
I wish !!
How to install 98SE after install XP vikasg03 Software Q&A 2 11-02-2008 01:42 PM
Which to install first? gofeddy Software Q&A 5 06-02-2007 07:19 PM
Can I install?? thilina Open Source 6 03-09-2006 09:24 PM
how to install ubuntu direct from install menu rather than first run it thru live cd arunks Open Source 10 31-08-2006 10:41 PM
How to install windows 2000(pro)After install of xp? rajas700 Software Q&A 4 23-10-2005 01:32 PM
- by chris
