Old 07-04-2008, 06:24 PM   #1 (permalink)
smile's Avatar
Talking Need help???
How to burn ISO images???????????
SR
smile is offline
Old 07-04-2008, 07:53 PM   #2 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Default Re: Need help???
With Nero Burning ROM ... That's so simple ..
Install Nero and just click on the ISO images....then click burn .. That's it !
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 09-04-2008, 09:31 PM   #3 (permalink)
Seed is the Life!!
shift's Avatar
Or mount the ISO images with any virtual drive software. then copy CD/DVD and select the virtual drive as SOURCE
shift is offline
