Old 07-04-2008, 03:24 PM   #1 (permalink)
s3Prosavage's Avatar
Default xp boot time problem........
i have windows xp installed on my computer.......few days ago i tried to reinstall xp but there was a power failure...n i dont have a ups.........so when i switched on da pc again two options occured....1.start windows xp
2.start xp setup................................so nw i have to chose bw the two since by default setup option is selected.....it wastes time.......so pls help me remove that second option n start xp automatically........if i not chose da setup option automatically loads n since it does nt found da xp cd it hangs there..........
s3Prosavage is offline
Old 07-04-2008, 03:33 PM   #2 (permalink)
Web developer
narangz's Avatar
Default Re: xp boot time problem........
Here's how you can do that:
1. Right click my computer
2. Click properties
3. ON the new window click advanced tab
4. Under startup & recovery click settings
5. Set the Default Operating System to XP (The other one is setup)
6. Edit the Boot.ini file & remove the setup startup line.
That's it
narangz is offline
Old 07-04-2008, 03:52 PM   #3 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
^exactly.. follow the same or u can use Easy BCD ...
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 07-04-2008, 05:31 PM   #4 (permalink)
this is my boot.ini file:
[Boot Loader]
Timeout=5
Default=C:\$WIN_NT$.~BT\BOOTSECT.DAT
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(0)partition(3)\WINDOWS="Micro soft Windows XP Professional" /fastdetect
C:\$WIN_NT$.~BT\BOOTSECT.DAT="Microsoft Windows XP Professional Setup"
wat to delete in this file?????????
Old 07-04-2008, 06:07 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
which windows you want to keep??
c:\windows or E:\windows??
ravi_9793 is offline
Old 07-04-2008, 06:15 PM   #6 (permalink)
c:windows...........i dont have any e:windows........
thx everyone for all your help........my problem has been solved........u ppl r great!!!!!!!!
How can I boot my computer at a preset time. ajaybc Software Q&A 1 19-08-2007 05:54 PM
is there a website which can explain the boot time erors?? tango_cash Software Q&A 4 28-07-2007 11:13 PM
Decrease boot time ashisharya Tutorials 10 19-06-2006 02:03 PM
Boot Up time...?? [lokesh] Software Q&A 2 16-03-2005 07:21 PM
redundant OS selection menu at system boot time. please help arko Software Q&A 3 20-02-2005 01:37 AM
