Old 07-04-2008, 03:00 PM   #1 (permalink)
hell boy
Default yahoo messenger problem
hi
i cant get yahoo messenger working in vista what to do i need it
like sly stallone i am bringing the pain the only difference is that i got SINGH in my name..,!!
MasterMinds is offline
Old 07-04-2008, 03:27 PM   #2 (permalink)
Web developer
narangz's Avatar
Default Re: yahoo messenger problem
What's the problem? Any errors? Please be more specific.
narangz is offline
Old 07-04-2008, 03:34 PM   #3 (permalink)
hell boy
humm
it installs perfectly but when i run i cant sign in to my account and after that when i close it and it minimizes to system tray{thats normal} and when i exit it from there then there is a msg. "this prodram requires flash.ocx file to run which is no longer included in this windows' version" i tried download flash.ocx from ocxdump.com but in vain....
Old 07-04-2008, 03:39 PM   #4 (permalink)
Web developer
narangz's Avatar
Which version of Yahoo Messenger have you installed?
Get the latest one from here messenger.yahoo.com
narangz is offline
Old 07-04-2008, 03:42 PM   #5 (permalink)
hell boy
i have downloaded the yahoo msg9 from softpedia
Old 07-04-2008, 03:50 PM   #6 (permalink)
Web developer
narangz's Avatar
get back to 8.1
9 is still in beta so it has many problems. it crashes on my system too.
Secondly when you try to sign in what happens? As you said you cannot sign in.
narangz is offline
Old 07-04-2008, 04:01 PM   #7 (permalink)
hell boy
that same error with tree options
new user, tryagain, sign in problems
Old 07-04-2008, 04:54 PM   #8 (permalink)
Intel OCer
amitash's Avatar
i had the same prob in vista wid 9 beta switch bak to 8.1 and it might wor...it worked for me....
My site: collegeclassroom.org
amitash is offline
Old 07-04-2008, 07:08 PM   #9 (permalink)
y2j826's Avatar
there is a special version of yahoo messenger for vista, try that and i am using yahoo 9 on vista its working fine for me
http://worldofy2j.blogspot.com
y2j826 is offline
Old 07-04-2008, 07:35 PM   #10 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Install the latest Flash Player from Adobe.com in your system and your problem should be solved.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 07-04-2008, 10:15 PM   #11 (permalink)
hell boy
tried that not worked
Old 07-04-2008, 10:21 PM   #12 (permalink)
Microsoft MVP
Then also try to register the ocx file. Open RUN and give following command:
regsvr32 %windir%\System32\Macromed\Flash\Flash9e.ocx
Here I have mentioned the file version of Flash player installed in my Windows. Change the file name acc. to your system. Check which .ocx file exists in "%windir%\System32\Macromed\Flash\" folder.
Old 07-04-2008, 11:29 PM   #13 (permalink)
hell boy
^^thanks...will give this a try.....i am a gr8 fan of urs for ur skinning work and those tutorial to give vista's look to xp......thanks for the interest......
Old 08-04-2008, 09:30 AM   #14 (permalink)
hell boy
now i really feel confused there is no ocx file in the above path
Old 08-04-2008, 02:32 PM   #15 (permalink)
Microsoft MVP
That means Flash Player is not installed in your system. Open following link in IE and download the flash player:
http://www.adobe.com/products/flashplayer/
Old 08-04-2008, 03:37 PM   #16 (permalink)
hell boy
^^^^but i have installed it
Old 08-04-2008, 04:14 PM   #17 (permalink)
Microsoft MVP
^^ Have you installed it using IE or Firefox? Since no .ocx file exists in your system, thats why I request you to reinstall it using IE.
Old 08-04-2008, 06:34 PM   #18 (permalink)
hell boy
i installed it using opera now will do using ie but i cant understand the difference with browser!!!v have to download the installer {no matter with which browser}
Old 08-04-2008, 06:59 PM   #19 (permalink)
damn busy...
utsav's Avatar
same problem here with me in xp using ym 9 beta
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 08-04-2008, 07:06 PM   #20 (permalink)
hell boy
thankgod i have got a same suffrer
o yea yea yea yea yea got it working got it working^^^^thanks V.G now there is a flash.ocx file there thanks a lot thanks
Old 08-04-2008, 07:54 PM   #21 (permalink)
Microsoft MVP
^^ My pleasure. Actually Yahoo! Messenger uses IE as default browser, thats why it was not detecting the flash player. When you installed it using IE, it detected and started working.
yahoo messenger problem prinz QnA (read only) 1 08-05-2007 10:46 PM
yahoo messenger problem narangz Software Q&A 6 10-05-2006 01:38 AM
yahoo messenger problem dgk.3007 Software Q&A 5 27-02-2006 10:38 AM
yahoo messenger problem ssk_the_gr8 Software Q&A 2 12-12-2005 07:12 PM
yahoo messenger problem roxisayshi QnA (read only) 8 28-04-2005 12:48 AM
