Old 04-04-2008, 10:35 PM   #1 (permalink)
prasad_den's Avatar
Default Odd problems with regard to Win XP.. explorer issues..!!
I have been having some weird problems with my Win XP SP2 since yesterday. Yesterday, when I tried to open gpedit or msconfig, I got some script error, asking me if I wanted to debug. Irrespective of the choice I click it persisted until I end the mmc.exe process from task manager.
Today, when I try to open gpedit, it gives no error messages. But I am able to see nothing in the extended page format. However, the standard page format appears correctly. The following screenshots will make things clear for you..!
And another problem I am facing today is that IE7 does not open at all. When I start IE7, a window opens and then closes immediately by itself..
P.S: My system is free of viruses and spywares and adwares..!
Finding more problems:
Drag and drop is not working..
Also I am able to copy or cut files, but when I right-click at some other location to paste them, the paste option is not highlighted.. Ctrl C and CTrl V too do not work... Someone help..!
prasad_den is offline
Old 04-04-2008, 11:19 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Odd problems with regard to Win XP.. explorer issues..!!
are you really sure? do a hijackthis log and post it here. google for ad-aware and spybot search and destroy.
if i were you, i would reinstall windows. first back up the settings, and then just 30 mins for setup. do it while you are watching tv or something...
dheeraj_kumar is offline
Old 04-04-2008, 11:43 PM   #3 (permalink)
prasad_den's Avatar
^^ Hijackthis analysis turns nil.. Nothing even remotely suspicious..!
and windows reinstallation is out of the question.. at least for now..!
Old 05-04-2008, 12:19 AM   #4 (permalink)
well, if you cant do a fresh install, atleast install it on top of existing one... that may help. you dont have to reinstall anything.
try "sfc /scannow"
or get rootkitrevealer from sysinternals. try checking with that.
How to fix the top 10 Internet Explorer issues anandk Tutorials 5 10-04-2007 12:27 PM
Post N73 music edition Issues/Problems/Suggestions Here Rockstar11 Buying Advice 8 06-04-2007 12:23 AM
how abt panasonic x500 in regard to sreen & cam quality????? pvr_harish Mobiles and Tablets 2 14-06-2006 04:59 PM
Problems regarding adressbar issues ... krishnansurya QnA (read only) 5 22-12-2004 03:39 PM
