Old 02-04-2008, 10:40 AM   #1 (permalink)
Fullbring
Zangetsu's Avatar
Default problem in XP Pro
I got a weired problem in my OS
1) The "Folder Options..." is not visible in Tools option
2) And also the TaskManager when i right clic on the taskbar & select taskmanager a msg pops up "the taskmanager is diabled by the sys admin"
but I m the only admin with my account only
Is it a virus problem or something else?
Zangetsu is offline
Old 02-04-2008, 10:50 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: problem in XP Pro
search for your solution:
[Windows] FreQuently AsKed ProBlems WITH SoluTions...
ravi_9793 is offline
Old 02-04-2008, 03:56 PM   #3 (permalink)
Hi
yes bro that is caused by a virus/worm/spyware.. etc etc..
neways ..if you want to enable folder options then use these registry files..
http://rapidshare.com/files/10425006...nhide.rar.html
After this...
to enable task manager..
• Click Start
• Click Run
• Enter gpedit.msc in the Open box and click OK
• In the Group Policy settings window
o Select User Configuration
o Select Administrative Templates
o Select System
o Select Ctrl+Alt+Delete options
o Select Remove Task Manager
o Double-click the Remove Task Manager option
method 2(task manager)
copy this to a notepad and save as anyname.reg
Windows Registry Editor Version 5.00
[-HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\TaskManager]
To enable registry editor go to start>run paste this there and press enter
REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Pol icies\System /v DisableRegistryTools /t REG_DWORD /d 0 /f
Regards
imageek is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
