Old 31-03-2008, 10:23 PM   #1 (permalink)
Can you hear it..??
windchimes's Avatar
Default System freezes during browsing
hi guys,
My system freezes unexpectedly during browsing..Connected via broadbad to
a 2GB Ram PC running XP SP2 OS and using Opera browser.. any idea why it happens...?
Secondly can anyone tell me the best free tools available for internet security against any kind of intrusion..
windchimes is offline
Old 31-03-2008, 10:32 PM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: System freezes during browsing
Next time, whenever you start browsing, run the task manager and minimize it(don't close it). If ur PC freezes, after it unfreezes, immediately go to task manager and see what was the CPU and RAM usage during the freeze. Since it happens only during browsing, it may be some issue with javascript on a website.
गीक होना माँगता
victor_rambo is offline
Old 31-03-2008, 10:39 PM   #3 (permalink)
anand1's Avatar
If you are using any addons then try to disable those addons and look if it works properly. Disable also the Toolbars you are using.
Visit this link to ko how to reset your IE7 Explorer if you are using this browser.
Technology On The Fly
anand1 is offline
Old 31-03-2008, 11:07 PM   #4 (permalink)
Can you hear it..??
windchimes's Avatar
thanks guys...but rohan..it never unfreezes but i have to manually restart it..
Old 01-04-2008, 08:03 PM   #5 (permalink)
Hi
do you have firewall or antivirus installed,if yes ..then i feel,your traffic is routed through them , so ...........
reagrds
imageek is offline
system freezes and monitor doesn't start callmeastha Software Q&A 3 17-01-2008 05:09 PM
My System Freezes :-( sysfilez Software Q&A 5 12-10-2006 02:41 PM
my system freezes . urgent amargupta Software Q&A 10 04-08-2006 11:01 PM
My system freezes suddenly mousereddy Hardware Q&A 2 27-10-2005 07:38 PM
AMD System freezes too much!! armourlength Software Q&A 10 06-06-2005 05:04 PM
