Old 27-03-2008, 10:08 AM   #1 (permalink)
Default Problem while connecting to internet through LAN...
Recently I've been having this peculiar problem of being unable to connect to the internet through the LAN connection of my hostel.
I encounter this problem whenevr I resume my lappy from hibernation or for some reason such as power cut I get disconnected frm LAN for a while.....
On resuming the icon on the taskbar says-"Access-Local" whereas this is supposed to be "Access-Local and Internet" ie:-for me to be able to access the net.
Unplugging n replugging the LAN cable works sometimes but not often,same luck wid disabling and renabling the LAN connection.
Nowadays all I can do is keep my fingers crossed so tht I can connect to the Internet.
My OS is Vista Business.
Any suggestions as I am at my wits end....
KoMbInAtIoN for Disaster
mad_hatter_11 is offline
Old 27-03-2008, 10:11 AM   #2 (permalink)
Default Re: Problem while connecting to internet through LAN...
It happened in all editions of Vista where the updates weren't installed. Just update using the "automatic update" feature all the updates and it will be solved.
You must also be facing the problem (most possibly) of not hearing anything when connected to headphones/earphones.
Finish the automatic update.
legolas is offline
Help me in connecting internet via wifi hayabusa_ryu Mobiles and Tablets 4 15-03-2008 01:58 PM
Connecting to internet sattumail Internet & WWW 8 28-02-2007 12:18 PM
problems connecting to the internet readermaniax Internet & WWW 5 12-08-2005 11:37 PM
Internet -Connecting Problem -Fedora Core3 karthik_rcs Open Source 3 24-03-2005 04:41 PM
