Old 25-03-2008, 11:11 PM   #1 (permalink)
Subbu loves Technology
sravan's Avatar
Default Group policy editor not opening
Whenever I try to open group policy editor by typing "gpedit.msc" the follwing error occurs
error shown in pic
plz help me
sravan is offline
Old 25-03-2008, 11:28 PM   #2 (permalink)
slugger's Avatar
Default Re: Group policy editor not opening
re-register the file devmgr.dll
slugger is offline
Old 26-03-2008, 12:12 AM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
start -->. run -->> type:
regsvr32 /u gpedit.dll
Again, start -->. run -->> type:
regsvr32 gpedit.dll
restart, your problem should be solved.
ravi_9793 is offline
Old 26-03-2008, 07:03 AM   #4 (permalink)
sravan's Avatar
When i tried to do as told above i am getting this error msg
Load Library(gpedit.dll)failed-Specified module cannot be found
sravan is offline
Old 26-03-2008, 07:14 AM   #5 (permalink)
Are you using Win XP Home Edition or Professional Edition? Group policy Editor is not available on Home Edition...
Arun
sakumar79 is offline
Old 26-03-2008, 07:19 AM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
Try this solution:
http://support.microsoft.com/default...1&PA=1&SD=HSCH
Or if that also dont work than..........
start -->> run -->> type this and click ok
sfc /scannow
Insert win XP CD, when asked , and restart after it is completed.
Should solve your problem.
Also refer to these articles:
http://support.microsoft.com/default...b;en-us;297064
http://support.microsoft.com/default...b;en-us;826282
http://support.microsoft.com/?kbid=326574
Old 27-03-2008, 06:35 AM   #7 (permalink)
sravan's Avatar
This doesn't solved my problem
sravan is offline
Old 27-03-2008, 08:50 AM   #8 (permalink)
TechTin.com
ravi_9793's Avatar
have you tried sfc /scannow
Old 27-03-2008, 06:18 PM   #9 (permalink)
sravan's Avatar
I didn't try that .Plz tell me another solution plz
sravan is offline
Old 28-03-2008, 06:31 AM   #10 (permalink)
sravan's Avatar
Unhappy Re: Group policy editor not opening
Hi
Anyone plz help me in this regard
sravan is offline
Old 28-03-2008, 07:05 AM   #11 (permalink)
Could you confirm if you have XP Professional edition and not Home edition?
You can also try Doug Knox's Security Console at http://www.dougknox.com/xp/utils/xp_securityconsole.htm
Arun
Old 28-03-2008, 06:03 PM   #12 (permalink)
sravan's Avatar
Wink Re: Group policy editor not opening
Mine is xp professional
Doug Knox's Security Console doesn't solved my purpose
sravan is offline
Old 31-03-2008, 07:42 PM   #13 (permalink)
sravan's Avatar
Help me plz
sravan is offline
Old 31-03-2008, 10:07 PM   #14 (permalink)
TechTin.com
ravi_9793's Avatar
why you are not trying:
sfc /scannow
Old 31-03-2008, 10:31 PM   #15 (permalink)
anand1's Avatar
This happened with you because Group Policy editor is not included in the Home Basic it is availble in XP Professional.
Follow these steps.
Click Start and select Run.
Type msconfig and Click OK.
Click Expand File.
Type framedyn.dl_ in the File to restore field.
Restore the file from the i386 folder on the XP CD.
Save it to the %systemroot%\System32 folder.
Follow these steps and look if this solves your problem or not.
Technology On The Fly
anand1 is offline
Group Policy Editor for Vista SP1? alsiladka Software Q&A 2 21-03-2008 02:41 PM
group policy settings yrakesh78 QnA (read only) 3 31-08-2007 12:16 PM
group policy ramharis Software Q&A 1 18-05-2007 09:38 PM
How can i get my complete group policy back ??? sandeep bhatia QnA (read only) 10 21-11-2006 08:47 PM
what happened to my group policy hansraj QnA (read only) 1 13-02-2006 04:33 PM
