Old 24-03-2008, 06:16 PM   #1 (permalink)
Default Google talk problem
Hello friends,
By mistake i pressed CTRL+V in google talk display and all my contacts got invisible. i dint knew what to do that time so i uninstall google talk and then try to downlaod the EXE file from google site. now that exe file is not downloading properly and unable to insetall google talk. kindly help me with this and is their any other messeger where i can use google talk.
I am able to use google talk through gmail which i dont want to use.
Thanks & Regards
Kunal.
Once a new technology rolls over you, if you're not part of the steamroller, you're part of the road
kunaltech is offline
Old 24-03-2008, 07:33 PM   #2 (permalink)
Default Re: Google talk problem
after you uninstall gtalk, if you try to install it again, it gave installation problem for me too.
go to program files -> google -> shift+delete the google talk directory and now run the installer again, it will work.
legolas is offline
Old 24-03-2008, 08:56 PM   #3 (permalink)
I did that but still same problem. i have attached the file how it looks after downloading.
Old 24-03-2008, 09:15 PM   #4 (permalink)
dOm1naTOr's Avatar
did u dl it with firefox?
just copy paste the file location from the dl history page under properties of the file nd paste it to new tab nd hit enter.
nd it ll re-dl the file and the exe will become usable.
It happens to me in firefox while dling mosy .exe files....it gives a useless file nd the re-dl just takes one sec the the exe will be usable.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 24-03-2008, 09:16 PM   #5 (permalink)
you mean you can not download it??
then I have zipped it and uploaded here. try getting this.
http://rapidshare.com/files/10199649...setup.zip.html
legolas is offline
Old 24-03-2008, 09:36 PM   #6 (permalink)
nope i dint do from firefox
Old 24-03-2008, 09:39 PM   #7 (permalink)
i was able to download
i have attached the file and i have point out how it looks after downloading
Old 24-03-2008, 09:55 PM   #8 (permalink)
thanks your ZIP file has work for me
now i able to install
Old 24-03-2008, 10:17 PM   #9 (permalink)
dOm1naTOr's Avatar
so, it was a currupt download file...this happens with most exe.
nyway i was thinking it as a bug of firefox...now another browser has same problem.
which browser did u use?
G3: XPS M1530 |
FZ 16.
Old 25-03-2008, 04:36 PM   #10 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
yes u r right sometimes exe files dont get downloaded properly ie stops @ 98% bt shows u 100% .....
have exp sometimes ....
so i just copy-paste the URL in download accelerator .... & jobs done ....
... W H O T ...
ax3 is offline
Old 25-03-2008, 08:08 PM   #11 (permalink)
dOm1naTOr's Avatar
i wonder why its not happening with ny other kinda files???only exe files..
and opera is gud at it...i use opera to dl exe files coz firefox may sometimes result in dumb files.
G3: XPS M1530 |
FZ 16.
Old 25-03-2008, 09:24 PM   #12 (permalink)
it has never happened to me in firefox or opera.
legolas is offline
Old 26-03-2008, 12:38 AM   #13 (permalink)
I use Internet Explorer Browser
Google-talk nazzguul... Internet & WWW 2 14-12-2007 12:36 PM
Google Talk Help expertno.1 Internet & WWW 51 06-09-2005 03:34 PM
Google talk cryptid Internet & WWW 1 03-09-2005 04:51 PM
GAIM and Google Talk Scorpion Open Source 10 31-08-2005 06:23 PM
Google Talk rajat22 Internet & WWW 2 25-08-2005 10:27 AM
