Old 24-03-2008, 12:41 AM   #1 (permalink)
Om Ma Ni Pä Me Hum
phuchungbhutia's Avatar
Default Dvd copy : dvd9 to dvd5
I need some help with copyin dvd . . I have dvd 9 ie 8 gb disc which i want to copy to two 4.5 gb discs ... How to do wat to use . . I have to make menu for the mother and also add subtitles ... How!?
Om Ma Ni Pä Me Hum: (perfection of-)
Om: generosity,- Ma: pure ethics,-Ni: tolerance n patience.- Pä: perseverance,- Me: concentration,-Hum: wisdom... Using Opera Mini Airtel NOP
phuchungbhutia is offline
Old 24-03-2008, 07:52 AM   #2 (permalink)
Attitude matters
Ponmayilal's Avatar
Default Re: Dvd copy : dvd9 to dvd5
With the freeversion DVDFab HD Decryptor, you can copy the DL DVDs to your hard disk. With the paid version DVDFab Gold or DVDFab Platinum, you can split and record it on two DVDs including menus with 100% quality.
Ponmayilal is offline
Old 24-03-2008, 02:39 PM   #3 (permalink)
Om Ma Ni Pä Me Hum
I found that nero recode can extract the titles very well but there is no option for menu . . .
Old 24-09-2009, 03:11 PM   #4 (permalink)
Here is a full guide on how to copy and compress dvd9 movies to dvd5 disks
waterfly99 is offline
Old 24-09-2009, 10:30 PM   #5 (permalink)
Om Ma Ni Pä Me Hum
Is that a freeware by any chance
Old 24-09-2009, 11:02 PM   #6 (permalink)
+1 for DVD Fab. Pretty easy to use as well.
Not sure of any freewares.
sujitm is offline
To copy Three VCD on one DVD CadCrazy Software Q&A 18 17-07-2007 08:24 AM
TOTAL COPY-Copy Stuff In A diff Way! rakeshishere QnA (read only) 17 28-02-2007 09:39 PM
Convert DVD9 to DVD5? dOm1naTOr QnA (read only) 8 22-05-2006 01:08 PM
Size Problem With Movies In DVD5... go4saket QnA (read only) 1 21-05-2006 11:35 PM
