Old 17-03-2008, 09:31 AM   #1 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Default How to protect USB memory drive from virus attack ??
Now a days most of us using USB flash drive for data carrying. But there
is a common problem with these USB flash drive for virus attack and spreading to other computer. Is there any way to protect the usb flash drive from virus attack when I plugin the USB flash drive to other computer which I donot know is a infected computer ?
Recently on right clicking on my pen drive I found that there is a option "Auto" added in the menu. Normaly the 1st option is "Open". I doubt it is a virus or something like, but it is not detected by the Antivirus software.
Then I have formated the flash drive and get rid of this.
________________________________________________
I like signature after 10 P.M.
skghosh44 is offline
Old 17-03-2008, 10:20 AM   #2 (permalink)
!! RecuZant By Birth !!
naveen_reloaded's Avatar
Default Re: How to protect USB memory drive from virus attack ??
best is to disable autorun feature...
and use of goos anti virus like nod32 / kaspersky /....
and best use >>> right click >> EXPLORE option... instead of double clicking ...
if u not sure of usb content .. best is not to double click...
Know My Thoughts..
Visit my Blog @ www.Urssiva.com
Visit My Tech Blog @ www.CloudTechnica.com
naveen_reloaded is offline
Old 17-03-2008, 05:05 PM   #3 (permalink)
slugger's Avatar
install ClamWin Portable on ur flash drive
u can use its on-demand scanner to run a scan f any files you transfer 2 ur drive
slugger is offline
Old 17-03-2008, 06:24 PM   #4 (permalink)
ajayritik's Avatar
Thanks for the info on the software slugger! will try it out today!
ajayritik is offline
Old 18-03-2008, 09:05 PM   #5 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Thanks to all for reply.
Old 26-03-2008, 10:49 PM   #6 (permalink)
Click Tools-->Folder Options and enable viewing of hidden files. You will see a file called "Autorun.inf". Delete that file and you'll no longer notice the "Auto" in the right click menu.
viswanadh is offline
Old 26-03-2008, 11:12 PM   #7 (permalink)
motobuntu's Avatar
@slugger, thanx buddy, very nice info.
A computer once beat me at chess, but it was no match for me at kick boxing.
motobuntu is offline
Old 26-03-2008, 11:31 PM   #8 (permalink)
slugger's Avatar
Welcome
slugger is offline
Old 27-03-2008, 02:16 PM   #9 (permalink)
dr_jimit's Avatar
thanks 4 d software.
dr_jimit is offline
Old 27-03-2008, 07:06 PM   #10 (permalink)
TheSaint
NucleusKore's Avatar
I protect my pen drive in college by booting from a live NimbleX cd and browsing in the library.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 06-05-2008, 02:45 AM   #11 (permalink)
Lightbulb Re: How to protect USB memory drive from virus attack ??
There is a software to protect your pen drive from viruses.
http://penprotectorenglish.wordpress.com
It write protect your pen drive or any flash drive, sd or mmc card.
Bye
bitmaster is offline
Old 06-05-2008, 03:36 AM   #12 (permalink)
GaurishSharma.com
gary4gar's Avatar
When you know your drive is infected, you can simple boot pc with any Linux live CD like knoppix. Delete the file(usually EXE) and reboot back into windows.
no hassles
gary4gar is offline
Old 06-05-2008, 07:00 AM   #13 (permalink)
Earlier, pendrives used to come with write-protect locking facility (similar to floppy drives), but nowadays, you cant seem to find that feature anymore... Even with such pendrives, when it is handled by the wrong person, it can be infected (personal experience)... You can try (1) disabling Autorun feature through registry editing, (2) blocking USB port Autorun through software like USB Firewall (not yet used it) or (3) loading it through Linux first...
Arun
sakumar79 is offline
Old 07-05-2008, 03:25 PM   #14 (permalink)
how does it work
it antivirus....
is it portable av...
means it is back up some virus defination files and we need to update that virus defination time to time ?
be who u r :
Saharika is offline
Old 07-05-2008, 03:36 PM   #15 (permalink)
GaurishSharma.com
gary4gar's Avatar
Originally Posted by Saharika View Post
how does it work
it antivirus....
Yeah, you need to update Virus definitions frequently and also it will scan your files while you copy it so slower speeds.
gary4gar is offline
Old 07-05-2008, 04:12 PM   #16 (permalink)
Wire muncher!
infra_red_dude's Avatar
There is NO on-demand scanner in ClamWin portable!! You hafta manually scan each file.
infra_red_dude is offline
Old 12-07-2009, 05:26 PM   #17 (permalink)
i'm using naevius usb antivirus
http://www.naevius.com/usb_antivirus.htm
johnice333 is offline
Virus Attack skippednote Software Q&A 3 11-02-2008 03:34 PM
Virus Attack ruthless Software Q&A 17 24-04-2007 08:54 AM
Virus attack!!!!!!! abhi_shake Software Q&A 6 25-06-2005 03:43 PM
TCP/IP attack: read to protect anomit QnA (read only) 1 05-05-2005 01:25 PM
Virus Attack FasTrack Software Q&A 14 06-11-2004 12:11 AM
- by Krow
