Old 15-03-2008, 07:21 PM   #1 (permalink)
Can you hear it..??
windchimes's Avatar
Default System restore doubts
I did a system restore few minutes back, but unfortunately got a program removed thereby.
The sad part is that the setup ie .exe file of the program also got removed.(Does that happen?)
There are only some files for the program in the Windows/Prefetch directory and a few files in the installed folder. And a few other files which I downloaded for this application
at the same time is in tact
I have two questions
1) Anyway to get back the setup file?
2) While doing system restore which all files are removed to get back to the specific checkpoint and which all files are affected?
windchimes is offline
Old 15-03-2008, 10:14 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: System restore doubts
Just undo the last restore...using same process.
ravi_9793 is offline
System Restore r4gs Software Q&A 5 12-12-2006 10:21 AM
System Restore Goes Away.... dinesh_mettur Software Q&A 1 19-11-2006 11:47 AM
Cant restore system using 'System Restore' Swappy Software Q&A 4 23-08-2006 10:33 AM
System restore mako_123 QnA (read only) 3 06-05-2005 02:43 PM
- by Krow
