Old 12-03-2008, 07:01 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Can you hear it..??
windchimes's Avatar
Default Drive letter and folder names turn blue
Hi guys,
After formatting only my c:drive and reinstalling windows I found that all the folder/filenames in certain drive which I haven't touched changed their font colour to blue. What is the reason?( I remember reading somewhere it has to do with the file system..true? But here I have the same files/m before and after formatting..rt?)
How can I restore the black colour for file names...
windchimes is offline
Old 12-03-2008, 07:41 AM   #2 (permalink)
Dreamweaver
Gigacore's Avatar
Default Re: Drive letter and folder names turn blue
you selected the option to compress files during the format. Now just turn of the Compression in Drive properties
Gigacore is offline
Old 12-03-2008, 09:18 AM   #3 (permalink)
Can you hear it..??
windchimes's Avatar
Thanks yaar..lemme check it
Old 12-03-2008, 11:24 AM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Yep. It happens while you are using NTFS file system. It compresses files to save disk space.
You can disable this feature from "Folder Options". There will be an option to "Show compressed files in blue color".
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 14-03-2008, 07:33 AM   #5 (permalink)
thanks guys it helped me too.
mkmkmk is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/82457-drive-letter-folder-names-turn-blue.html
Drive letter and folder names turn blue Software Troubleshooting Question This thread Refback 03-03-2011 09:41 PM
How to change drive letter? anish_sha QnA (read only) 11 03-02-2008 08:30 AM
drive letter.. magneticme200 Software Q&A 6 08-01-2008 08:28 PM
How to change drive letter(f: ----> d:) CadCrazy Software Q&A 10 10-03-2007 11:58 PM
Windows File Names Show Up In Blue! ravillion10 Software Q&A 3 25-08-2006 09:10 AM
- by Krow
