Old 09-03-2008, 06:26 PM   #1 (permalink)
Pawned!... Beyond GODLIKE
fun2sh's Avatar
Default PROBLEM : Different Drive LETTERS in XP n VISTA!
I have ACER 4710 lappy with 160gb HDD. Currently I have 5 partitions viz, C,D,E,F,G! I have VISTA installed in Drive C. My drive D is completely empty(but formatted though!).
Now the problem is when I install XP it shows my D drive as F, similarly Drives E,F,G are also displayed with different letters. After the installation of XP in drive D(which it shows as F) , i checked it in VISTA WHICH SHOWED THEM WITH CORRECT LETTERS (i.e from C to G) but again if i start my XP THEN IT SHOWS THE DIFFENT DRIVE LETTERS( D now is F in XP n others too get changed)
PLEASE HELP ME GUYS HOW TO CORRECT IT!!
If God has indeed created Himself in His own image, then I submit to you that God is a cockroach !!!!!!!!
fun2sh is offline
Old 09-03-2008, 06:39 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: PROBLEM : Different Drive LETTERS in XP n VISTA!
Change the drive letters as you want using Disk Management.
Pathik is offline
Old 09-03-2008, 06:55 PM   #3 (permalink)
fun2sh's Avatar
^i cant change the drive letters in vista as it shows them in correct way n i cant change the drive letter of drive F(which is D in vista) as XP is installed in that itself
fun2sh is offline
Old 09-03-2008, 07:08 PM   #4 (permalink)
Krazy_About_Technology's Avatar
maybe your vista is not in c. Vista shows any partition it is installed in as C. So thats what causing all this confusion. what XP is showing is the real drive C.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 10-03-2008, 01:24 AM   #5 (permalink)
fun2sh's Avatar
xp n vista both shows the same drive as C.
again here it is the partition configuration
partition no----drive letter in vista------drive letter in xp
0--------------------C----------------------C
1--------------------D----------------------F
2--------------------E----------------------E
3--------------------F----------------------G
4--------------------G----------------------D
fun2sh is offline
Old 10-03-2008, 07:15 AM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
Just put a good label on each volume and get it over with that way.
I've experienced this too, with Vista making whichever drive it is installed upon post XP its C.
Harsh J
www.harshj.com
QwertyManiac is offline
change drive letters sumigizlov Software Q&A 9 18-02-2008 11:41 PM
Enabling the drive letters??? baby_grandma Software Q&A 3 11-09-2007 08:08 PM
drive letters iMav Hardware Q&A 3 04-10-2006 12:17 AM
Drive Letters shwetanshu QnA (read only) 2 26-01-2005 10:29 AM
DRIVE LETTERS kadal27 QnA (read only) 2 01-10-2004 02:45 AM
