Old 09-03-2008, 02:02 PM   #1 (permalink)
tech_cheetah's Avatar
Default vista lnk files problem
One of the shortcuts on my Vista desktop was not showing any icon and it was also not pointing to any application. So I selected the application manually for that and by mistake "Always use selected application for this kind of file" was enabled.
Now all the shortcuts (lnk files) are pointing to that application !!
How can I restore all the lnk files back to their default applications ?
Be honest . By that way u can be sure that the world is short of atleast one rascal.
tech_cheetah is offline
Old 09-03-2008, 02:22 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: vista lnk files problem
Open notepad and paste following code. Save the file with name "Vishal.reg" (including quotes) and then run it:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\lnkfile]
@="Shortcut"
"EditFlags"=dword:00000001
"FriendlyTypeName"="@shell32.dll,-4153"
"IsShortcut"=""
"NeverShowExt"=""
[HKEY_CLASSES_ROOT\lnkfile\CLSID]
@="{00021401-0000-0000-C000-000000000046}"
It should work.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 09-03-2008, 03:37 PM   #3 (permalink)
Problem is still there
Old 09-03-2008, 04:15 PM   #4 (permalink)
Microsoft MVP
OK. Try following code and restart your system:
[HKEY_CLASSES_ROOT\.lnk]
@="lnkfile"
[HKEY_CLASSES_ROOT\.lnk\ShellEx]
[HKEY_CLASSES_ROOT\.lnk\ShellEx\{000214EE-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\.lnk\ShellEx\{000214F9-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\.lnk\ShellEx\{00021500-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\.lnk\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}]
[HKEY_CLASSES_ROOT\.lnk\ShellNew]
"Handler"="{ceefea1b-3e29-4ef1-b34c-fec79c4f70af}"
"IconPath"=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,\
  74,00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,73,\
  00,68,00,65,00,6c,00,6c,00,33,00,32,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,\
  31,00,36,00,37,00,36,00,39,00,00,00
"ItemName"="@shell32.dll,-30397"
"MenuText"="@shell32.dll,-30318"
"NullFile"=""
[HKEY_CLASSES_ROOT\.lnk\ShellNew\Config]
"DontRename"=""
@="Shortcut"
"IsShortcut"=""
"NeverShowExt"=""
Old 09-03-2008, 05:27 PM   #5 (permalink)
No changes yet
Infact the first time I ran registry file, there was a notification that "Sync GUI failed"
Old 09-03-2008, 10:59 PM   #6 (permalink)
All the registry entries were done and verified thru regedit, but still the problem persists.
Is there any other way ?
Old 09-03-2008, 11:49 PM   #7 (permalink)
Got it fixed thru the attached reg file
File Type: zip lnkfix_vista.zip (987 Bytes, 24 views)
Old 08-06-2008, 01:50 AM   #8 (permalink)
Attached file is corrupted. Not a zip neither a reg file
laroby75 is offline
Old 08-06-2008, 10:57 AM   #9 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
http://www.winhelponline.com/fileasso/lnkfix_vista.zip
Problem with digit forums attachments, not with the file itself.
dheeraj_kumar is offline
VISTA TUTORIAL: List of VISTA System Files to be Hacked Using Resource Hacker Vishal Gupta Tutorials 9 22-10-2007 11:45 PM
need boot files of vista (ultimate) dvd vineeth.gk Software Q&A 2 26-06-2007 11:00 PM
Vista Problem( exe files not opening) CadCrazy Software Q&A 4 19-05-2007 07:50 PM
Seeing hidden files in VISTA? paragkalra Software Q&A 4 20-04-2007 03:12 PM
Problem Deleting Vista Files... khattam_ Software Q&A 2 10-04-2007 10:21 PM
- by Krow
