Old 06-03-2008, 07:30 PM   #1 (permalink)
filth is me
forever's Avatar
Unhappy Problem playing HD files
Hi friends. i recently acquired the Lord of the rings triolgy in HD. they are in .mkv format. im having trouble playing them. the video is choppy and goes out of sync with the audio and lags a lot at times. my config would be p4 2.52 GHz and 512 MB ram with an onboard 64MB card. the description of the mkv files goes like this:
Releasname: The.Lord.Of.The.Rings.Return.Of.The.King.2003.720p .HDTV.x264-THOR
File Type: mkv
Video: x264 4 Mbit/s
Audio: English DD 5.1 384 Kbit/s
is there any way possible i could play them without any issues. much appreciated, thanks.
forever is offline
Old 06-03-2008, 10:50 PM   #2 (permalink)
mayanksharma's Avatar
Default Re: Problem playing HD files
hmm..i thought they all were encoded with DTS audio!
Anyways, did you try playing in media player classic with FFD codecs? And what about VLC? Look, if both these players are unable to render the screen and audio properly then ur hardware is incapable to play HD video format. Processor is fine, though try increasing the RAM to 1GB and adding a entry level GPU like 7300GT or 7600GS ! I think, ur mobo should have AGP 8X slot...right?
mayanksharma is offline
Old 06-03-2008, 11:00 PM   #3 (permalink)
TheSaint
NucleusKore's Avatar
Try VLC Player
NucleusKore is offline
Old 06-03-2008, 11:16 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
512MB should allow to play 720p, where as problem would be with VGA GMA 900 / 865 / 845 / older VIA Chipset wont allow the play back
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 07-03-2008, 11:41 AM   #5 (permalink)
filth is me
forever's Avatar
i tried every codec pack and player, but i believe your right choto cheeta, im on an old pc so i guess i have to live with it
forever is offline
Old 07-03-2008, 11:42 AM   #6 (permalink)
slugger's Avatar
his availbale RAM will be less than 512 MB
onboard GPU chipsets will be allocated RAM from the system RAM
u got a pwerful enuff processor for 720p HD. its got 2 b ur RAM and GPU chipset causin d bottleneck
slugger is offline
Problem playing video files mad1231moody Software Q&A 6 13-01-2008 05:50 PM
Problem with media player 10 while playing .mpg & .dat files & Direct X Sharad Software Q&A 1 11-09-2006 04:45 PM
Display problem when playing 3GP files Cool G5 Software Q&A 1 08-09-2006 06:47 PM
Problem with chat softwares when playing files on mic Charley Software Q&A 5 13-03-2005 01:56 PM
I am having problem in playing DAT, MPEG files on my system courser QnA (read only) 2 29-01-2005 04:16 AM
