Old 06-03-2008, 01:34 PM   #1 (permalink)
mannuforall
mannuforall's Avatar
Question Unable to login XP -need help
Hi!
yesterday I work on my pc and it work all fine then I shut down. but when today I login again, it unable to login. when I enter password and hit on enter it shows login and suddenly it automatically logout and back to login screen. I also tryto login with admin & guest, safe mood but result same.
I have XP in dual boot & IInd XP, which I used occasionally is working fine.
plz help me to login my Ist XP which have all soft & settings, asap...
mannuforall is offline
Old 06-03-2008, 01:38 PM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: Unable to login XP -need help
y u need two XP....
if u prefer dual boot then install different OSes.....
as 4 ur problem "a virus or a system file conflict"
pls give more details regarding ur problem....i.e wat softs u installed before this incident
Windows OS Calculator Bug
Sqrt(9) - 3 = check the answer
Zangetsu is offline
Old 06-03-2008, 04:41 PM   #3 (permalink)
mannuforall
Thumbs up Re: Unable to login XP -need help
no software install/unist. my antivirus avast is updated daily by net automatically. MY both XP working properly since last 2 years. & reason for both XP is to work in emergency as now I'm using it.
Old 11-03-2008, 07:23 AM   #4 (permalink)
mannuforall
anyone have the answer?
or it is a useless forum???
Old 11-03-2008, 09:48 AM   #5 (permalink)
motobuntu's Avatar
Buddy, I guess only a windows repair installation can save u.
A computer once beat me at chess, but it was no match for me at kick boxing.
motobuntu is offline
Old 11-03-2008, 10:16 AM   #6 (permalink)
Mad and Furious
redhat's Avatar
First learn to be kind...
1) Two Win XP OSes in dual Boot is as stupid as it can be
2) You have not provided enough information
3) The above post of urs is too rude to attract help
redhat is offline
Old 15-03-2008, 03:43 PM   #7 (permalink)
TooR
alok4best's Avatar
^ +1..
I wish !!
alok4best is offline
Old 15-03-2008, 11:46 PM   #8 (permalink)
mayanksharma's Avatar
hmm...u could've asked the problem in proper way rather than being rude.
Anyways, u can try repairing the XP using the Boot Disc. And when u are in the recovery console, try repairing the damaged SAM file.You can replace the SAM database with a backup one which is stored in the System Volume Information folder. Or, simply boot using Live Linux Disc and backup the necessary data then format!
Though, i still think that Booting into the SAFE MODE should have helped.
mayanksharma is offline
Old 16-03-2008, 12:28 AM   #9 (permalink)
manishjha18's Avatar
userint file is corrupted
manishjha18 is offline
Old 16-03-2008, 01:00 AM   #10 (permalink)
hi... even i think either repairing XP or formating the hdd is good soluiton.. as u mentiond that u havent been able to login properly even in safe mood..!
try it..!
all the best!
sjstays is offline
HELP! HELP! HELP! I can't login!!!!!! The Unknown Open Source 21 18-07-2007 10:08 PM
Cant login In Adsense readermaniax QnA (read only) 4 15-03-2006 05:44 PM
Unable to login to digitpatron abhijitroy QnA (read only) 2 10-11-2005 11:53 PM
Login Shortcut saROMan QnA (read only) 2 24-04-2005 08:54 PM
