Old 04-03-2008, 03:35 AM   #1 (permalink)
Default XP boot/startup problem
i got a problem each time i start my pc after the intel sign shows i have this error problem :
http://allyoucanupload.webshots.com/...76793354304134 , each time i have to run my pc i have to press F4 to resume loading windows .. any solutions ?
onuser is offline
Old 04-03-2008, 09:35 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: XP boot/startup problem
I think there is some problem with RAM chip. Please remove one chip, and try boot. DO this for both individual RAM chip.
ravi_9793 is offline
Old 04-03-2008, 12:43 PM   #3 (permalink)
Krazy_About_Technology's Avatar
Actually your system is prompting you to change memory configuration to increase performance. The motherboard supports ram in dual channel mode that theoretically doubles the performance of DDR ram. What i can figure out from the picture is that you have 4 RAM modules and they are not of same model. What you can try is that open your system and find out the RAM modules. There will be two pairs of memory slots lets call them A and B. Pair A will have slots A0 and A1 and similarly B will have B0 and B1. please note that i am assuming this at my own, you will not find any mark like A0 etc on or near the slots. You can pretty much assume any pair as A and other as B.
Now what you need to do is to choose any pair and replace its modules with one another, i mean for example if you choose pair A then place module currently in A0 into A1 and that of A1 into A0. I hope you got my point.
See if it helps.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
startup problem magneticme200 Software Q&A 12 05-02-2008 01:33 AM
Startup Problem visujinu Hardware Q&A 8 28-12-2007 08:02 PM
Help me... Getting startup problem jyoti.mallick02 Software Q&A 7 08-12-2007 07:42 PM
No boot menu at Startup q3_abhi Software Q&A 6 06-11-2005 01:33 AM
startup problem sujeet2555 QnA (read only) 1 28-07-2005 05:18 PM
- by chris
