Old 03-03-2008, 08:52 AM   #1 (permalink)
Cool urgent vista issue
hi guys i hv bought hp pavilion laptop and its having vista premium in 12 gb recovery partition. i want to know how can i write it on a dvd. plz help me
n tell me which software i have to use for this..
sushantsaurabh is offline
Old 03-03-2008, 09:02 AM   #2 (permalink)
Default Re: urgent vista issue
Please check backup software in your notebook, bcoz compaq notebook comes with backup software, yours is premium notebook. Backup software will make disks of your size (600mb/4gb/8gb).
gcbeldar is offline
Old 03-03-2008, 09:05 AM   #3 (permalink)
a_g = JPKN
s18000rpm's Avatar
make a recovery disc using the in-built recovery disk creator
only ONE set of disk can be made.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 03-03-2008, 09:31 AM   #4 (permalink)
can i install vista through this disk in future?
Old 03-03-2008, 10:08 AM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
Yes but it will be not a clean vista installation but as you got when you purchsed the system. Most prolly it'll also wipe your HDD clean before install.
infra_red_dude is offline
Old 03-03-2008, 11:36 AM   #6 (permalink)
You gave been GXified
gxsaurav's Avatar
Note down the existing Vista serial key for your computer using which Vista is installed right now. Then either get a Vista DVD from the vendor or from "other means", reinstall vista on a clean partition & use the existing key to activate.
about.me/gxsaurav
gxsaurav is offline
Urgent Hidden Folder Issue arfakchoudhury Software Q&A 3 20-04-2007 09:04 PM
HELP: Vista firewall issue Faun Software Q&A 7 23-03-2007 01:14 PM
Forum Query / Issue ....Urgent :) Wizard No.2 Internet & WWW 2 23-03-2005 02:58 PM
- by chris
