Old 02-03-2008, 08:56 PM   #1 (permalink)
Default problem with xp boot up "operating system not found"
installed norton ghost 2k and i clone a 160 gb hard disk with mine after system restarts error message came like this "operating system not found"
prakashr85 is offline
Old 02-03-2008, 10:51 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: problem with xp boot up "operating system not found"
This may help you.
Solving windows XP boot/ StartUp problems
ravi_9793 is offline
Old 03-03-2008, 03:08 AM   #3 (permalink)
pritamonline's Avatar
I had faced same problem "operating system not found" after creating image for the first time with Norton ghost 2003. I had selected my c drive for creating image and it would be saved on d drive. After clicking on few next buttons, it asked me to restart. And then XP never loaded !! .
I had re-installed the WinXp OS SP2
Tip: Always copy important files/folder to some other drive before creating image!
Pritam
pritamonline is offline
Old 03-03-2008, 08:14 AM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
As a old member of the forum, I must say.......
"You dont need to add your site link after your each post. Avoid this habit"
I think you were once warned also by some moderator.
Old 03-03-2008, 04:33 PM   #5 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Yes, i have already issued a warning to him.
@Pritam. This is your last chance. You will most definitely face a ban if i catch you doing the same thing again.
kalpik is offline
Old 03-03-2008, 04:42 PM   #6 (permalink)
Enter recovery console in XP setup,
There type "fixmbr" and "fixboot" (Without quotes).
Xccentricity is offline
Old 03-03-2008, 05:16 PM   #7 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
^^ to do that you first need to insert XP CD, then boot from it.(just adding information)
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 04-03-2008, 07:32 PM   #8 (permalink)
Distinguished Member
anandk's Avatar
http://support.microsoft.com/kb/321626
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
SOUL software- "Hardware Not found" error! ali.kureshi Software Q&A 1 12-01-2008 03:38 PM
"System stability problem"-Help me immedietly deepak.krishnan QnA (read only) 3 26-10-2005 07:32 PM
ERROR: "Missing Operating System" Aseem Nasnodkar Internet & WWW 22 22-10-2005 12:04 AM
"MSDOS compatibility mode file system" problem... NikhilVerma QnA (read only) 6 23-11-2004 11:09 PM
- by chris
