i was given the job 2 reinstall windows XP in my frnd p.c .......so i enter the bios & set 1st boot option as cd rom. then after putting the bootable XP disk in the cd rom i pressed ny key 2 boot after sum times nothing happens & the setup doesn't run instead of that old xp which is installed in his pc starts.... i also used digit ultimate boot cd but its also boot (its tools menu comes) but none of the keyboard keys work after that. (lik- press F1 for HHD tools)...... this is the 1st time i m facing this type of prob.
