Old 29-02-2008, 02:34 PM   #1 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Unhappy Wierd Problem
Whenever i turn off or restart my pc the computer doesn't turn off completely but instead it show a black with a cursor on it and remains as it is untill i manually turn it off .
Please help!
thanx in advance...
I spit Rainbows.
skippednote is offline
Old 29-02-2008, 03:32 PM   #2 (permalink)
dhanusaud's Avatar
Default Re: Wierd Problem
Reinstalling the OS is only perfect solution to get rid of this problem. I mean fresh installation of OS your are using.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 29-02-2008, 06:33 PM   #3 (permalink)
M3TAL H3AD M3
Question Re: Wierd Problem
isn't there any other way.
Old 29-02-2008, 07:15 PM   #4 (permalink)
dhanusaud's Avatar
I think there is some problem with registry. Cleaning regitry may solve your problem. But as I hv already said before, reinstalling OS may fix your problem permanently.
Becoz I have faced same problem too.
Wierd Problem in XP Prabhagaran Software Q&A 12 22-09-2007 12:05 PM
A wierd problem.(Probably virus or hardware problem) spyder Software Q&A 2 09-01-2007 06:52 PM
a really wierd problem vikram Software Q&A 2 15-05-2006 10:49 AM
Wierd problem with my net drvarunmehta QnA (read only) 4 04-02-2005 11:23 PM
- by chris
