Old 29-02-2008, 12:45 AM   #1 (permalink)
tango_cash's Avatar
Default do bin and iso files have larger files sizes than it's contents???
hi i have some bin and iso files when i load them in alcohol the total size of the contents is less than the file size of the iso or bin file.
for e.g i have this iso file which has size of 314mb. when i load it in alcohol the total size of the contents is just 271mb.why is that???where is the remaining 43mb used??
i am thinking of copying the contents of the iso to my hdd and delete the iso file .this way i will save 43mb.and similarly more space when i do the same for my other iso and bin files.but i am afraid will the data become corrupt?
am i missing something??is some extra memory needed which i am unable to see.
please help
tango_cash is offline
Old 29-02-2008, 01:43 AM   #2 (permalink)
Default Re: do bin and iso files have larger files sizes than it's contents???
alcohol is some virtual drive software ?...
Well, usually ISO is same of size of its content.. but when mostly data is compressed.. eg.. a Linux distro with ISO of 1 GB can come up with 3 GB of software when installed... but as ISO its always 1 GB.. whether u mount it or keep it as it is.
~Ricky
» Looking for someone to partner with me in Indian Linux forum
Free domain is available ! I am also at Indian Forums.
Ricky is offline
Old 29-02-2008, 03:42 AM   #3 (permalink)
Fresh Stock Since 2005
Yes, ISOs and BINs are not compressed image formats, however, they may contain compressed files.
@tango_cash
yes, ISOs can take up more space than the total amount of files. And the other space is just nothing. However, some (usually very less) may be occupied by "Boot Image" if the ISO is bootable. If the ISO is not bootable, you may extract and keep the files and del the ISO. However, if the ISO is bootable, it is a gud idea to backup the boot-image with a software like IsoBuster (however it is a software that u shud pay for, the Free function it provides will serve the purpose)..
And BIN images are sometimes made for copy-protected disks. So extracting the contents may not let you install the software.
http://www.khattam.info
khattam_ is offline
Old 29-02-2008, 04:23 PM   #4 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
if u r talking abt movies then some files r 2 make THAT .mpeg,dat etc files behave as moviecd when u popin the cd\dvd ......
2 save that space, u can extract & delete the original iso file ....
... W H O T ...
ax3 is offline
Old 29-02-2008, 04:48 PM   #5 (permalink)
pushkaraj's Avatar
Arrow Re: do bin and iso files have larger files sizes than it's contents???
+1
@tango_cash, decide whether to extract the contents of the image file or not depending on the type of data that is there in it. If it's a movie cd/dvd image then u can extract it safely, but if it's a game or software image, then better leave it as it is.
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
Old 29-02-2008, 08:29 PM   #6 (permalink)
tango_cash's Avatar
thank u all for the help.actually the iso and bin files are of tutorial dvd's. they are not any sftwr(but i will keep that in mind if i have sftwr dvd's iso or bin file. khattam_)
so i guess it is pretty safe if i copy the content and delete the iso bin files and save myself some space.
how to convert dvd files to rmvb files raj4frns QnA (read only) 1 21-12-2006 10:26 PM
contents of my office files were deleted !!! Omsck Software Q&A 7 03-08-2006 09:54 AM
calculating the time, larger matrices! help pls. legolas QnA (read only) 2 13-10-2005 09:14 AM
converting.pdy files directly to .doc files. kumarn_2004 QnA (read only) 5 23-02-2005 10:47 PM
- by chris
