Old 28-02-2008, 03:48 PM   #1 (permalink)
FRESH mind
Samystic's Avatar
Question AVI compression help
Hello Digigans!!!
I have a Xvid AVI RIP of a movie (Original - for backup purposes)...the size is around 1.1GB... I want to make at below 700MB...I am looking for a free software to reduce the size...without much loss in quality...Any alternative to VirtualDUB...i m not very comfortable with it...
waiting for a reply...
Thanks...
Samystic is offline
Old 28-02-2008, 05:07 PM   #2 (permalink)
M$™ Certified Spammer
entrana's Avatar
Default Re: AVI compression help
try alltoavi its free
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 28-02-2008, 05:09 PM   #3 (permalink)
anarchist
Posts: n/a
anyvideoconvetor -free
Old 28-02-2008, 06:00 PM   #4 (permalink)
vaibhavtek
Posts: n/a
Anyvideoconvertor is free but it doesn't compress too much as Samystic has said.
Btw nice avatar think u take interest in GIMP .
Follow this:-http://www.thinkdigit.com/forum/showthread.php?t=79820
Old 28-02-2008, 06:25 PM   #5 (permalink)
Commander in Chief
QwertyManiac's Avatar
AutoGK perhaps? One of the best in that kind of a task.
www.autogk.me.uk
Harsh J
www.harshj.com
QwertyManiac is offline
compression utility ismart Software Q&A 23 20-02-2007 10:34 AM
how compression take place????? dittualex QnA (read only) 2 17-11-2005 07:12 PM
Compression help vijaythefool QnA (read only) 21 20-02-2005 09:33 PM
vcd compression redhat_adi QnA (read only) 5 13-02-2005 05:54 PM
- by chris
