Old 27-02-2008, 10:39 AM   #1 (permalink)
Devoted Metalhead \\m//
Drizzling Blur's Avatar
Default iTunes problem / Alternative s/w for iPod
I run iTunes on my laptop, HP DV6226, the program crashes every time i launch it, I even uninstalled it and then installed it back, nothing seems to work. Kindly suggest something.
Also suggest an alternative s/w for accessing the iPod, there was a s/w i came across which was a simple drag and drop process, kindly help.
Everyone's got a good life, i got the best.
Drizzling Blur is offline
Old 27-02-2008, 10:43 AM   #2 (permalink)
Think Zen.
ray|raven's Avatar
Default Re: iTunes problem / Alternative s/w for iPod
http://www.simplehelp.net/2007/07/08...ing-your-ipod/
Hope this helps you,
ray
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 24-03-2008, 09:49 PM   #3 (permalink)
Thank You.
The best s/w from that list was "SharePod" recommended for hassle free file transfer.
Last edited by Drizzling Blur; 24-03-2008 at 09:49 PM. Reason: Automerged Doublepost
iTunes Alternative to sync iPod Charan Software Q&A 7 23-10-2008 01:56 PM
Alternative for iPod shyamno Mobiles and Tablets 16 26-12-2007 10:51 PM
Please Help-Unable to install iTunes for my iPOD!!! gauravharalalka Audio 11 27-06-2005 01:42 PM
- by chris
