Old 27-02-2008, 12:31 AM   #1 (permalink)
Default trying to fit a webpage into my browser-please help
I have a 14 inch monitor.
when you go to this link
http://www.hdfcsec.com/TradingDemo/index.html
and click on launch virtual trading platform it opens a new page but that does not fir into my browser(IE AS WELL AS FIREFOX)neither does it give me a link so that I can paste into the address bar and scroll sidewards.
Please help as this is causing my a problem as I am unable to invest money.
Thank you
viruses is offline
Old 27-02-2008, 01:24 AM   #2 (permalink)
Tech.Masti's Avatar
Default Re: trying to fit a webpage into my browser-please help
Try Opera
Tech.Masti is offline
Old 27-02-2008, 03:29 AM   #3 (permalink)
Security Exp
47shailesh's Avatar
Hi Viruses,
There is a disclaimer at the bottom of the page, it reads
Your display resolution should be set to 1024 x 768 to view the demo
We Love Once, And When We do We do it Well
47shailesh is offline
Old 28-02-2008, 12:10 AM   #4 (permalink)
i tried with the display resolution without much luck.only the words become smaller but the web page does not fit.opera i dont think will be any good.
any other solution.
viruses is offline
Old 28-02-2008, 01:13 AM   #5 (permalink)
Security Exp
47shailesh's Avatar
^I am able to view the full content perfectly @1024 x 768
Old 28-02-2008, 01:32 AM   #6 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
any other solution.
Did you activate the "Fit to Width" control? Activate it by Ctrl+F11 or View>Fit to width.
That will eliminate horizontal scrolling!
गीक होना माँगता
victor_rambo is offline
Old 28-02-2008, 06:58 AM   #7 (permalink)
Tech.Masti's Avatar
^^ ya, activate Fit to Width and then see
Old 28-02-2008, 04:44 PM   #8 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
its not ur problem bt sites [design is] ...... or try full screen mode .....
... W H O T ...
ax3 is offline
Webpage Ishan QnA (read only) 8 05-03-2007 03:26 PM
how 2 add irc to webpage santu_29 QnA (read only) 4 17-03-2006 09:14 AM
How to save the URL of a webpage within the webpage? arvlee QnA (read only) 3 07-09-2005 04:59 PM
Kinks from a webpage djmykey QnA (read only) 3 25-05-2005 10:03 AM
Garbage in webpage mohanty1942 QnA (read only) 5 27-12-2004 07:36 PM
- by chris
