I just formatted C Drive of a machine and loaded WIN XP PROF SP2. ( It was running on WIN 98 SE before). Now when I start the PC, it shows the following messsage and when I press OK it simply reboots.
lsass.exe - System Error
An I/O operation initiated by the Registry failed unrecoverably. The Registry could not read in, or write out, or flush, one of the files that contain the system's image of the Registry.
[ OK ]
The computer makes it through POST without problems. Windows XP pro splash screen comes on and goes away and this error pops up when you would normally expect the welcome screen or logon prompt.
I have done error-checking on the disk, and can log in SAFE mode. I don't want to refomat. Is it a virus? PLEASE HELP!
Its a Intel Celeron-S 1300 MHz 128 MB RAM 40 GB hard disk machine.
And at the BIOS screen this message comes:
CMOS checksum error- Defaults loaded.
Press F1 to Continue. Del to enter SETUP/Q-Flash
if it helps.
