Old 24-02-2008, 11:25 PM   #1 (permalink)
9437077259
go4saket's Avatar
Default Problem with Truecrypt?
Hi Guys!
I have some very very confidential date in my computer which I keep in encrypted format using Truecrypt. For testing purpose, I installed a key logger in my computer and then mounted my encrypted date using Truecrypt. After that I checked my key logger software and to my horror, I found that the password I typed was actually recorded by the key logger. This fails the purpose of encrypting the data as any key logger can steal my password.
I have used Bestcrypt before and it had a feature where in the typed password was also encrypted and so the key logger couldn't log the actual password.
Is there any such option in Truecrypt? What can I do that my password doesn't get recorded? I cant use a password header file. I need a normal encrypted file that can be mounted by typing the password.
Please help. Thank you.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 25-02-2008, 06:44 PM   #2 (permalink)
Default Re: Problem with Truecrypt?
Never used any of such software but now I need to use it, so just wondering why did u shift to Truecrypt when u were using bestcrypt, which one is better?
Can it crypt the whole partition or only folders & files?
ranjan2001 is offline
Old 25-02-2008, 09:25 PM   #3 (permalink)
9437077259
go4saket's Avatar
It can encrypt partitions as well as make containers where in you can keep your files and folders in encrypted format.
The main reason of shifting from Bestcrypt to Truecrypt is the portability of software. While you can carry Truecrypt in your Flash drive, you cannot do the same with Bestcrypt. So, incase if you want to take your date in encrypted format to any other computer, you have to make sure that that computer also contains Bestcrypt, which if using Truecrypt, you can easily carry the software in your pen drive.
Win 7 Ultimate
go4saket is offline
Old 25-02-2008, 09:34 PM   #4 (permalink)
Interesting to know that...........let me install truecrypt & test it.
Thanks
Old 02-06-2008, 05:24 PM   #5 (permalink)
Thumbs up Re: Problem with Truecrypt?
There is another good free encryption software - Rohos mini. And it's portable. You can take your encrypted data to another computer, and there is no need for software to be installed on that computer, thus you can open your data without having administrative rights.
Staggy is offline
Bestcrypt or Truecrypt - Which 1 is better? go4saket QnA (read only) 4 03-06-2008 12:39 PM
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by chris
