Old 23-02-2008, 10:38 PM   #1 (permalink)
ECE0105's Avatar
Question Partition Lost after changing Drive Letter.
Hi,
I had tried changing the Drive letter of a Partition on my second HDD and it shows the status "Unallocated" and I get an error when trying to re-create the partition (Pls. check the Attachment).
Please help in getting the data back from the partition, since I am unable to even format it to a new one.
Some of the happiest people in the world do NOT have Everything... They just make the Best of Everything life brings their way... So, Stay HaPpY.... Smile Always.... :-)
ECE0105 is offline
Old 24-02-2008, 02:48 AM   #2 (permalink)
dare_devil's Avatar
Default Re: Partition Lost after changing Drive Letter.
plz be brief about what you did and how.
i changed my drive laters for many times of my 2 hard disks, i never got any problem. may you do some mistake
dare_devil is offline
Old 24-02-2008, 04:07 AM   #3 (permalink)
ECE0105's Avatar
Well, Like I said, I have 2 HDDs, and to diff. b/w the two, I made Partitions C,D,E and F from HDD1 and then G as the Optical Drive and then H & I for HDD2.
It was actually G & H for HDD2 and then I as the DVDRW.
So, I swapped it. The G Drive is actually working fine (Which was H earlier) and no issues with that. But when I changed I to H, it just did not show the status as a NTFS Partition and showed the status as an empty space.
Tried rebooting the PC and tried closing and opening Disk mgmt multiple times to no avail.
Since, I am not able to format the partition, I am unable to recover data as well...
ECE0105 is offline
Old 24-02-2008, 10:02 AM   #4 (permalink)
Khojne se to bhagwan bhi milta hai............Partition kya cheez hai........
Orange Juice is offline
Old 24-02-2008, 09:02 PM   #5 (permalink)
pushkaraj's Avatar
if u can, do a system restore. That should solve the problem. Restore ur system to a point before this problem happened.
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
Old 24-02-2008, 09:43 PM   #6 (permalink)
dare_devil's Avatar
if you windows xp bootable cd then boot from it, afetr all steps, when it asks for instalation drive, select your drive, press l for deleting partition, then create partition of unpartitioned space either here or from disk mgmt
i think it may solve your problem
How to change drive letter? anish_sha QnA (read only) 11 03-02-2008 08:30 AM
drive letter.. magneticme200 Software Q&A 6 08-01-2008 08:28 PM
How to change drive letter(f: ----> d:) CadCrazy Software Q&A 10 10-03-2007 11:58 PM
Ambiguous Drive Letter!!! IrfanK Software Q&A 3 30-07-2006 08:51 AM
USB stick drive letter Aijaz Akhtar Peripherals 5 12-08-2005 12:10 PM
- by chris
