which DivX converter r u usin
if it is showin
unsuprted files it obviously menas that d sw does not support *.dat files for conversion
check the list of file types it supports
usually such converter sws will have support for
*.mpg files
so i suggest that u first convert the
*.dat file to
*.mpg file using
VCDgear and then use the mpg file for conversion
another soln wud b 2 use
SUPER © v2008.build.25
it supports the use of *.dat files and will compress it using divx codec in an avi ontainer
