Old 22-02-2008, 11:09 AM   #1 (permalink)
Default xp-64bit problem
I have installed the 64 bit XP.After installing , i installed the audio drivers(Realtek).the drivers get installed,i cud see them in my add/remove programms.but there is no sound and the sound devices in controll panel also doesnt show the device drivers.what is the problem?one thing ,during installation,two files cudnt be copied as there was a problem in the disc.is this the reason?i forgot the file names.plz help.
bhaskar is offline
Old 22-02-2008, 02:18 PM   #2 (permalink)
slugger's Avatar
Default Re: xp-64bit problem
check if the Windows Audio service is enabled
it should be enabled nd put it to Automatic
slugger is offline
Pentium 2.66 GHz, 64bit demha7 CPU / Motherboards 14 20-08-2005 09:28 PM
128 bit or 64bit? mandar5 QnA (read only) 3 19-08-2005 07:56 PM
I need Linux 64bit zegulas Open Source 7 13-05-2005 03:21 PM
Far Cry 64Bit edition devilhead_satish Gamerz 3 13-05-2005 10:50 AM
ASUS K8V DLX AND K8S MX FOR AMD 64BIT kumars CPU / Motherboards 7 15-01-2005 11:47 AM
- by chris
