Old 22-02-2008, 10:57 AM   #1 (permalink)
tango_cash's Avatar
Default i need to add my bsnl broadband usage details.pls suggest how can i add it.
hi i have received a huge bill from bsnl.so i want to add the usage to make sure there is no totaling mistake.
as the dataone users may be knowing bsnl gives a huge list of usage data.
i want to add all the kb's.
i think it can be done in exel but dont know how.
pls help.
tango_cash is offline
Old 22-02-2008, 11:00 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: i need to add my bsnl broadband usage details.pls suggest how can i add it.
http://duf.sourceforge.net/
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 22-02-2008, 05:09 PM   #3 (permalink)
tango_cash's Avatar
i am unable to download that sftwr.
Old 22-02-2008, 06:59 PM   #4 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Check this out
http://www.softpedia.com/get/Interne...e-Finder.shtml
techtronic is offline
Old 24-02-2008, 12:47 PM   #5 (permalink)
tango_cash's Avatar
the site for checking usage i use is http://bbservice.bsnl.in and the above software does not work for it.
Old 24-02-2008, 12:49 PM   #6 (permalink)
-----ATi-----
nvidia's Avatar
^^If you are a FF user, then try THIS
http://twitter.com/akshayms
nvidia is offline
Old 25-02-2008, 08:55 PM   #7 (permalink)
The Researcher
Go to the usage site as directed by BSNL(old or new as the case may be). Before that download and install paperless printer which is free for non-commercial use. http://www.rarefind.com/paperlessprinter/downloads.html
Now login to the usage site and take print out using paperless printer in excel format(paperless printer supports many output formats).
Ramakrishnan is offline
BSNL Broadband Usage meter? gunda_26 Broadband and DTH 7 07-04-2008 12:56 PM
how to c usage details??? ramsingh QnA (read only) 8 08-01-2008 01:01 AM
Help I can not access BSNL Broadband Usage report ornalink Software Q&A 17 27-03-2007 11:58 PM
BSNL Broadband Usage enjoy Broadband and DTH 21 12-06-2006 12:25 PM
How 2 Know The Bsnl Dataone Usage kuldeep bhardwaj Broadband and DTH 3 04-05-2006 05:25 PM
- by chris
