Old 22-02-2008, 10:34 AM   #1 (permalink)
Mad and Furious
redhat's Avatar
Default driver_irql_not_less_or_equal error
Friends, I am getting this driver_irql_not_less_or_equal error when I try to boot my PC.
Restarting too does not help, but Safe Mode works just fine.
I am currently logged into safe mode with networking to get help here.
Some please help me quick!!!
How do I solve it?
I have not installed any new hardware/software in my PC in the past 2 months now!!
redhat is offline
Old 22-02-2008, 10:36 AM   #2 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Default Re: driver_irql_not_less_or_equal error
its some driver error only.reinstall video\sound drivers
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 22-02-2008, 10:40 AM   #3 (permalink)
Mad and Furious
redhat's Avatar
I checked with device manager and all drivers seem fine...
anyways, will try re-installing, Thanks
redhat is offline
Old 22-02-2008, 10:45 AM   #4 (permalink)
Alter Bridge=GOD
if u try sending the error report to MS it will show that--this error is caused when some device stops working and reinstalling drivers is the solution.
Old 22-02-2008, 10:49 AM   #5 (permalink)
Mad and Furious
redhat's Avatar
^^ I cant start my PC, hence no way to send it to MS...
redhat is offline
Old 23-02-2008, 03:48 PM   #6 (permalink)
Fresh Stock Since 2005
Seems like some Driver Problem. Update your Graphics Driver.
Also check your RAM for failure...
http://www.khattam.info
khattam_ is offline
Driver_irql_not_less_or_equal rahul964 Software Q&A 2 23-01-2008 09:13 AM
DRIVER_IRQL_NOT_LESS_OR_EQUAL indrajit Software Q&A 19 16-10-2005 01:32 AM
DRIVER_IRQL_NOT_LESS_OR_EQUAL??????? cvvikram Software Q&A 3 26-08-2005 01:35 PM
Windows XP Error -Driver_Irql_not_less_or_equal hbk88in Software Q&A 8 16-06-2005 08:14 PM
driver_irql_not_less_or_equal in WINXP Sp1 vk123 Software Q&A 3 07-10-2004 02:46 AM
- by chris
