Old 21-02-2008, 12:53 PM   #1 (permalink)
Default Help....virus Folder.exe
Hai Friends,
I need an urgent solution for the following
My Computer infected with a Virus Which creates inside Shared Folders a foldername.exe file.
kmvinodkm is offline
Old 21-02-2008, 06:28 PM   #2 (permalink)
dare_devil's Avatar
Default Re: Help....virus Folder.exe
dont know abt the virus but i hav a suggestion
arrange your icons by type and show them in group, so that you will not double click or open any virus having icon of folder
dare_devil is offline
Old 21-02-2008, 06:55 PM   #3 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Its brontok
41 Kb each chain reaction
Go to safe mode & remove using Spybot & Avast
(or any other Nt spware & Nt virus)
Just press F8 to when computer starts to go into safe mode)
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 21-02-2008, 07:01 PM   #4 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
Ahh.. I remeber solving same problem a couple of months ago but couldn't find that thread now..
OK here is it again:-
1.) Download Latest Antivirus (Kaspersky-recommended)
2.)Install IT (It wont be a problem...)
3.) Turn Off System Restore Service by Going to System Properties/System Restore TAB.
4.) In Safe Mode.. Scan Your PC. Delete every infected file..(It can mess your system badly... so be prepared.)
5.) Boot in normal mode and scan again.
7.) I think problem will be solved, so come here and post that problem is solved.
Quiz_Master is offline
Old 22-02-2008, 06:07 PM   #5 (permalink)
I tried Kaspersky. But the problem is not solved yet.
Virus file size is 789kb (new folder.exe and regsvr.exe files are making in every folder).
Anybody got this virus before..
Please Help
Old 22-02-2008, 06:53 PM   #6 (permalink)
p@rkour
zebanon's Avatar
Please Help
do u know in which folder(.exe) ur virus is located???
can u see any .exe file in any of C folders...
use avast, it might work 4 u....
Keep Thinking Hard , anytime u can be wid a great IDEA!!!!!!!!!......:)
This is my new blog in which i m sharing my ideas n thoughts in engineering life..
http://enggstudent-zebanon.blogspot.com/
zebanon is offline
Old 22-02-2008, 07:09 PM   #7 (permalink)
In every shared folder it is creating.
Old 22-02-2008, 07:21 PM   #8 (permalink)
p@rkour
zebanon's Avatar
ok hav u tried avast???
zebanon is offline
Old 22-02-2008, 08:37 PM   #9 (permalink)
ruturaj3's Avatar
Download SDFix.
ruturaj3 is offline
Old 22-02-2008, 09:05 PM   #10 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Please Help
newfolder.exe is detected by kav ,u must update to latest virus definitions......or try this, upload that newfolder.exe file to this site http://www.virustotal.com/ it will scan ur file with various av's n will give the result...download and install any of the av's that detects this virus.
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 23-02-2008, 09:55 AM   #11 (permalink)
Ecko's Avatar
Avast is the best
Just install it & click on yes when asked 4 boot time scanning
Ecko is offline
Old 23-02-2008, 03:26 PM   #12 (permalink)
Fresh Stock Since 2005
Can you attach the folder.exe here. Just password protect it with WinRAR before uploading and do post the password. Lets see what it is made of....
http://www.khattam.info
khattam_ is offline
Old 25-02-2008, 06:31 AM   #13 (permalink)
hey why not remove it manually....
first see wether u can access msconfig and task manager......
if yes then let me know.......
urvan4ce is offline
Old 25-02-2008, 12:57 PM   #14 (permalink)
smile's Avatar
Smile Re: Help....virus Folder.exe
Scan with Mcafee 8.5i surely u will find the virus
SR
smile is offline
Old 27-02-2008, 06:18 PM   #15 (permalink)
Thumbs up Re: Help....virus Folder.exe
Thank u . Scanned with Virustotal and found the solution.
Using Norton Antivirus with latest updates problem rectified
Old 29-03-2008, 04:02 PM   #16 (permalink)
regsvr.exe (1.06 mb) is a new virus. people get confused with the "microsoft corparation" written is its description properties.
this virus keep complete track of action of the user, also takes a snapshot every 30 sec and saves them at c:recycled\WinLiveUpdate32\scrdata\
u may like to visit this site for complete details:
http://piyushlabs.wordpress.com/regsvr/
piyushlabs is offline
Old 29-03-2008, 06:27 PM   #17 (permalink)
Lightbulb Re: Help....virus Folder.exe
I was affected by this virus few days back and i have posted an 'how to' article to remove this virus check it out at
http://amiworks.co.in/talk/how-to-re...oruninf-virus/
or get a latest virus definition updates for your favorite antivirus and hope that it works
thecancerus is offline
how to remove new folder.exe virus from ipod? imagineer_aman Software Q&A 3 16-12-2007 01:16 PM
Remove Desktop.ini & Folder.htt virus HTML.Redlof.A binoyxj Software Q&A 2 10-12-2007 06:04 PM
virus in System volume information folder Shikhar Software Q&A 3 16-08-2005 08:01 PM
Folder.htt and desktop.ini...! Is it a virus...? ramprasad Software Q&A 8 28-02-2005 11:45 AM
Folder.htt:Is It A Virus?? Maverick340 Software Q&A 13 18-01-2005 01:06 PM
- by chris
