Old 20-02-2008, 05:59 PM   #1 (permalink)
UBERGEEK
PCWORM's Avatar
Default Plzz help!!
After booting i get a strange Dialog box as follows:---
wat does it mean, and how to get rid of it? is it because of a virus...
I scanned my pc with bitdefender-free edition and found 8 viruses including "win32.worm.ahkheap.a" and "trojan.agent.aach" and selected to delete all the files....
Im not even able to delete or disinfect the files containing the above two viruses,,,,the av confirms it has deleted the files, but after rebooting the files
again appear...
PCWORM is offline
Old 20-02-2008, 06:14 PM   #2 (permalink)
vaibhavtek
Posts: n/a
Default Re: Plzz help!!
I think u have load Autokey v1.06 and enable them to start at startup of the OS..
I think that is the only reason behind it.
Old 20-02-2008, 06:34 PM   #3 (permalink)
UBERGEEK
PCWORM's Avatar
I really dont have any info on how does it work....
btw,,the virus files which i talked abt are located in the same C;;/heap14a folder...
so wat is the solution for it?
I hav not tried such kind of software!
PCWORM is offline
Old 20-02-2008, 06:38 PM   #4 (permalink)
vaibhavtek
Posts: n/a
Just look at the title bar of the box.
Scan pc with good antivirus..
There was a thread in the Technology section telling abt the ranking of the AntiVirus.
Search the forum and u will get.
Just use which is in 1.
Old 20-02-2008, 06:43 PM   #5 (permalink)
UBERGEEK
PCWORM's Avatar
ok ill try that,,,but is there any other way to stop it? like editing a registry entry???
PCWORM is offline
Old 20-02-2008, 07:29 PM   #6 (permalink)
hullap's Avatar
boot a live cd and delete the file
and turn off system restore
hullap is offline
Plzz Help smile Software Q&A 2 13-11-2007 01:05 AM
Plzz help me !!! jasperjunnu Hardware Q&A 1 19-03-2007 12:44 AM
plzz tell me, how can...... sandeep bhatia QnA (read only) 2 30-11-2006 11:22 PM
ppl said 5.1...but didn't said which one..can u plzz suggest... killzone Hardware Q&A 7 13-10-2006 04:35 AM
Plzz help me hl2.. medigit Gamerz 6 24-03-2005 12:54 AM
- by chris
