Old 19-02-2008, 10:40 PM   #1 (permalink)
Software Engine
chandru_skc's Avatar
Question System hangs on inserting DVD
Guys i have a pentium D dual core pc with asus motherboard and running xp sp2... the problem is whenever i insert a dvd, my system hangs permanently with out any notice even task manager can not help me out...
plz.. help me...
chandru_skc is offline
Old 19-02-2008, 10:52 PM   #2 (permalink)
slugger's Avatar
Default Re: System hangs on inserting DVD
is it a recent problem or it has been happenin since begining?
if it is a recent problem then wat was it that u did just b4 u started facin the problem
how much RAM ur comp got?
if u got an AV then try disabling that and c
even b4 that do 1 thin?
1.) dont change any config in ur comp yet
2.) Clear all entries in evnt viewer - application & system in particular
3.) put ur DVD in the tray. If it hangs then let it remain in that state for 10-15 mins
4.)if unable to wok on the OS then restart the comp
5.)Go back to event viewer and see all the entries that are marke as cdrom and atapi
just post the messages u get
slugger is offline
Old 20-02-2008, 02:36 AM   #3 (permalink)
plz.. help me...
i don't think it has something to do with dual core. i had same problem on amd.
i solved it with a system reinstall and a lot of headache.
xyanna is offline
Old 20-02-2008, 09:49 AM   #4 (permalink)
did you try disabling the autoread feature??
legolas is offline
Old 20-02-2008, 12:19 PM   #5 (permalink)
Software Engine
i have got 1 gb ram
can u reply in detail...
Old 20-02-2008, 12:45 PM   #6 (permalink)
Fullbring
Zangetsu's Avatar
Autoread means Autoplay option which is designed 2 play optical media
automatically (the moment u pop in 1 CD it starts playin in a media player )
it is created by .inf file in the root dir....in the CD/DVD e.g Digit DVD/CD which
we use..
Regarding ur problem u have 2 chec ur DVD whether its perfectly ok(i.e
critical scratches,its shape is good or not,it has cracks in the center or not etc)
If u have checed all dat then try using any other DVD which u think is perfect
or used it previously....
also try 2 chec dat DVD in a frnds PC....see wat happens....
ok my conclusion would abt ur problem:
1.Bad DVD(unreadable)
2.DVD drive lens
3.Antivirus Blocking (a virus ..)
4.DVD drivers
Zangetsu is offline
Old 20-02-2008, 01:05 PM   #7 (permalink)
Intel OCer
amitash's Avatar
if all the above dosn work then do a system restore...if tis is happening even after the system restore u mite have to reinstall ur Os
amitash is offline
System Hangs at night!!1 The Day Walker! Hardware Q&A 4 29-07-2007 01:24 AM
System hangs..help linardni QnA (read only) 3 10-02-2007 03:59 PM
system hangs and doesn't start callmeastha Software Q&A 7 26-08-2006 04:36 PM
PC hangs when inserting CD's lahratla QnA (read only) 7 05-07-2005 11:44 AM
HELP!!! SYSTEM HANGS TOO MUCH hsnayvid QnA (read only) 26 21-04-2005 05:27 PM
- by chris
