Old 15-02-2008, 12:41 AM   #1 (permalink)
Default Not able to install xp pl help me?
I jus want to overwrite my old xp..bec i got so many errors..so i jus tried to install by clickin on the setup icon..the installation opened..After tat wen i cliked to Install xp from the "what you want to do list" it gave me an error saying
"Setup cannot continue because the version of windows on your computer is newer than the version on the cd" ...And der is only cancel and details option i cant go further than this..what shud i do?
I also tried by restarting and booting from cd but after loading everything the blue screecame with an error so was not able to install tat way also
what should i do?..I want to repair or replace the whole xp without losing files
roonie is offline
Old 15-02-2008, 03:37 AM   #2 (permalink)
sauravktr's Avatar
Default Re: Not able to install xp pl help me?
Get a Another XP CD with SP2
" 99% computer Problems are between the PC & the CHAIR "
sauravktr is offline
Old 15-02-2008, 09:46 AM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
1) get windows XP Sp2 CD..and try to install it by booting from CD.
2) If you just want to repaid...you you can do one thing:
start -->> run -->> type sfc /scannow -->> ok-->> inseret windows XP when asked.
ravi_9793 is offline
Old 15-02-2008, 12:33 PM   #4 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
my frd do FORMAT first 2 avoid any overlapping of files ........
& then install new os ......
... W H O T ...
ax3 is offline
Old 15-02-2008, 03:21 PM   #5 (permalink)
I jus wanna repair only to get back in safe mode as am not able to ...i tried yur run scannow thing after clikin ok command prompt comes and closes in a second..wat to do it dint ask any cd..command prompt automaticaly closed in a second
roonie is offline
How to install 98SE after install XP vikasg03 Software Q&A 2 11-02-2008 01:42 PM
how to install ubuntu direct from install menu rather than first run it thru live cd arunks Open Source 10 31-08-2006 10:41 PM
HDD install... imported_tarang Hardware Q&A 5 14-02-2006 08:00 PM
Cant install O.S shay4u QnA (read only) 7 30-11-2005 03:13 PM
How to install windows 2000(pro)After install of xp? rajas700 Software Q&A 4 23-10-2005 01:32 PM
- by chris
